Hair Used in this in store product
mister-moviemister-movie Posts: 17
edited October 2024 in Product Suggestions
I was wondering what the name of the hair being used in this store product. I know the character is Kids 4 but no mention of the hair. Thanks!
Also I was wondering if anyone knew the outfit worn in this photo. The character is Marley for Matt and Maddie. Looks like some type of body suit.
  • Moved to Product Suggestions as it is not a Daz Studio applicaiton topic.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,485
    edited October 2024
    most legacy hairs parented props anyway so that could even be an adult hair and I have so many I also would have no idea, that one doesn't stand out
    you could try the transfer active morphs dialogue for clothing under the edit figure tab to fit M4 clothing
    if it doesn't work load the M4 obj mesh in your runtime geometries on K4 under figure morphloader pro to create an active morph to transfer, they all share the same vertex order just different UV mapping V4, A4 etc too
    (I typed that last paragraph the wrong way around in the message which cannot be edited so resharing here as others can help too if dressing K4 the issue)
    pro tip
    add morphs for all the other legacy 4 generations to all your others, you could do their UV mapping too with the obj files under surfaces but it needs to be saved as a duf file not a cr2
    then you can interchange clothes with transfer active morphs on all of them
    (it needs the morph though and unlike genesis figures that has to either be loaded everytime in morphloader or injected from one saved as a. injection using ExP a messy progress)
    to avoid this save your figures as duf files with all the morphs loaded you want
  • mister-moviemister-movie Posts: 17
    edited October 2024
    After a lot of searching I found the hair: Clio Hair, I agree it's hard to find older hair with all the morph and the like.
    Solved: With some help the clothes in question is Preschooler-ultra-bodysuits. Thanks!
    Post edited by mister-movie on
