Poser 13 - anyone using it?
Is it worthwhile to upgrade to Poser 13? What features were actually improved? etc etc... your opinions of it overall, or just stick to an old version?
  • Poser 13 was mostly a big upgrade for 3D photoreal animators. At 13.3 it's now pretty mature and bug-fixed. But note that Poser 14 is apparently around the corner, possibly (my guess) before Black Friday / Christmas? Which will likely mean discounts on Poser 13.
    The “Windows 10” system spec is only to cover their backs. 13 runs fine back to Windows 7, with the only drawback being you can't use Ken's paid-for scripts from the Renderosity Store (since only a later Windows OS has the required decryption module).
    12 and 13 still interface fairly painlessly with Vue (now wholly free, incidentally), importing scenes nicely once the software is told where things are. Just make sure you keep your old Poser 11 installed and with its runtime - the Vue SDK will expect to find that. Some Poser 12-only characters (Pink 2.0) and new complex Blender Cycles X shaders may not convert well, but nearly all older content will. Vue also serves to replace all the old PoserFusion plugins, since it exports your Poser imports to the latest versions of big-beast 3D software packages and also to game engines and VR etc.
    12 and 13 switched up to using Python 3, so many of your old Poser 11 / Python 2 scripts won't work. But by now there are plenty of free replacements for nearly everything. See here for a directory.
    Lots of changes in 13 due to the new Blender Cycles X (aka SuperFly in Poser) render engine in Poser 13. There's a lot to get your head around, in terms of a new approach to render settings. But once mastered, you get much faster rendering - especially on animations and complex scenes.
    Improved Intel Open Image Denoise (OIDN), now a key feature in speeding up render times. You can now also denoise the Raytrace Preview.
    Updated Walk Designer and Talk Designer. Also default Viseme mappings for "all Cartoon Characters", though I assume that means only the characters in the free 13gb content bundle. So far, as I know, no Visemes for the Nursoda toon fantasy characters.
    Maximum Undo limitation increased to 200.
    Slight improvements to Comic Book Preview real-time rendering. Less 'chips' in the line-art, seemingly due to a double-pass with slightly different settings and then an insta-composite of the two versions of the same line-art?
    Import and Export for Render Presets.
    Also a number of changes only of interest to clothing and content developers.
    The UI is much the same, thankfully there was no disastrous UI makeover by Kevin the Tea-boy!  Also, of course there's the usual long backwards compatibility with older saved scenes.
    If adding 13 alongside Poser 11, you'll also want to consider what was added in Poser 12. Adaptive sampling for faster renders. Superfly rendering into a layered .PSD including depth passes etc. Superfly making PNGs with background transparency.  Funky Cycles nodes inc. 'hair' and PBR materials. Dual graphics-card support. NVIDIA 30 series cards support. Many Materials Room improvements. Python Pillow support.
    Hope that helps!
  • davesodaveso Posts: 7,919
    that is an awesome overview for sure. Thank you very much. I haven't been using Poser, but I do have 11 floating around on a drive somewhere. the price of 13 is now only $79 for an upgrade, so its tempting. I would assume 14 won;t be that inexpensive at the beginning.. I started using Poser a version 1, and have always likes using it. I know a lot of people don;t get along with the ui, but I like it. Always seemed very intuitive to me.
  • I am using Poser 13
  • vagabondallenvagabondallen Posts: 24
    edited December 2024
    Using it? It's how I made my Red Cat comic series.
    Post edited by vagabondallen on
  • WandWWandW Posts: 2,903
    Genesis 2 was my go-to Poser figure, so I stopped at Poser 11 since the DSON importer was no longer supported in later versions.
    However, I built a new machine, and never have gotten around to installing Poser.  Studio works OK for me, but i miss the Material Room and the Morph Brush...
    its on sale at $79 upgrade again. today is already last day.
  • Thank you for the review.
  • StezzaStezza Posts: 8,882
    I don't use Poser or DS but I did buy 13 when it was on spesh for the content that came with it to maybe use in Carrara cool
  • I use Poser 13, Poser 11, Daz Studio, Carrara, Bryce, Blender and Vue. Poser has some excellent features like animated textures as standard and being able to create morphs right there in the viewport. Also, the ability to replacie body parts of a figure by swapping in props. The older Daz characters like generation 3 and 4 are superb and fun to use in Poser, Carrara or DS.
  • Ghost_TrainGhost_Train Posts: 61
    edited May 2025
    Poser 13 is pretty rad overall, but I currently prefer to work in 12 for the faster animation preview rendering (this won't affect most people though).  I wish DAZ and Poser would stop being silly after their splitup and rekindle the love they once had together.
    Post edited by Ghost_Train on
  • LlynaraLlynara Posts: 4,772
    edited May 2025
    I got Poser 12 on Humble Bundle recently for $25. Finally got around to installing on my art computer (it was in another state.) Haven't used it much. Would consider upgrading to 13 or 14 for the right price, but I'm not doing much rendering at the moment. Great to hear Vue is free now, will check that out.
    Post edited by Llynara on
  • GreybroGreybro Posts: 2,609
    It renders a comic style in no time and and that alone prompted me to get it. That and the nostalgia. Have it installed but almost never use it.
  • Ron KnightsRon Knights Posts: 2,402
    I remember when it was announced that Bondware had purchased Poser. It appeared they were going to make some massive improvements, etc.
    I held off on purchasing the upgrade. I hadn't used Poser in many years. But i still felt a strong connection. I got started in the 3D communities with Poser 4. (I'd actually bought Poser 1 at one time. It was from Fractal Designs.)
    But I wanted to see if they released any compelling new content to rival DAZ's DAZ Studio content.
    That still hasn't happened. And I haven't upgraded either.
    Poser 14 was just released
  • and apparently according to several Facebook friends no longer has the Cloth Room
  • LeanaLeana Posts: 12,934
    Yes, I saw that on the product page at Rendo too:
    Notable With This Release
    SuperFly render engine upgraded to use latest stable version of Cycles
    Intel One API ARC GPU Card Support
    Material Room: Return of the Simple Material Tab provides an easier, faster way to make Physically Based Materials
    Scene Backgrounds: Consolidated and simplified on the Simple Material Tab and the Display Menu
    GLTF/GLB Figure export
    Removal of the Cloth Room simulation feature
    Windows-only distribution
    I havent used Poser for a long time, but is the Cloth Room a huge deletion? Reading the description of P14 on Rendo it seems its kind of a gateway product to something else?
  • HavosHavos Posts: 5,621
    The cloth room was needed to use dynamic clothing in Poser. So the equivalent would be for DAZ to stop support dForce clothing. I would say that is a pretty serious deletion. I read they intend to introduce another dynamic cloth solution at some time, but that could be way off in the distance.
  • I'm still at verison 13 but the preview makes it hard for me to work with HDRI-illuminated scenes.
