Duplicate ID's issue
RAMWolffRAMWolff Posts: 10,382
Messed myself up creating new shapes for a figure.  Now I have duplicate ID's and I tried the older Fix Duplicate ID's script, I think Richard made but I keep getting errors.  So maybe there's a newer version of this script out there?
Really love to get his resolved.
Thank you
Richard
  • crosswindcrosswind Posts: 10,268
    edited October 2024
    With DS 4.21+, you shouldn't get "duplicate IDs issue" anymore from what you made... as DS creates unique url when you create / save morph assets. However, you still have chance to get "duplicate formulas issue" in a single morph asset ~~
    It's easy to fix the former issue by using a script but not for the latter issue . So, better confirm which type of issue did you get  ~
    Post edited by crosswind on
  • RAMWolffRAMWolff Posts: 10,382
    This is what pops up.
    536 x 139 - 23K
    ... and DS log ~~ A message box is not enough.
    Oh, so sorry
    Duplicate:
        File: H:/Users/Public/Documents/My Library/data/HiveWire 3D/Dawn 2.0/Base/Morphs/Richard McCormick/Johon-Plus/DD-Johon-Body.dsf
        Owner: Dawn2
        Input URI: Dawn2:/data/HiveWire%203D/Dawn%202.0/Base/Morphs/Richard%20McCormick/Johon-Plus/DD-Johon-Body.dsf#DD-Johon-Body-
    RAMWolff said:
    Oh, so sorry
    Duplicate:
        Owner: Dawn2
    Only these lines under Duplicate: ? If so, open DD-Johon-Body.dsf with Notepad++, check if there're any duplicate coding blocks of formulas.
    "id" : "DD-Johon-Body-0xa448199",
                "name" : "DD-Johon-Body",
                "parent" : "/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#Dawn2-1",
                "presentation" : {
                    "type" : "Modifier/Shape",
                    "label" : "",
                    "description" : "",
                    "icon_large" : "",
                    "colors" : [ [ 0.3960784, 0.6313725, 0 ], [ 1, 0.5019608, 0 ] ]
                "channel" : {
                    "id" : "value",
                    "type" : "float",
                    "name" : "Value",
                    "label" : "DD-Johon-Body",
                    "auto_follow" : true,
                    "value" : 0,
                    "min" : 0,
                    "max" : 1,
                    "clamped" : true,
                    "display_as_percent" : true,
                    "step_size" : 0.01
                "group" : "/02_Body/01_FullBody",
                "formulas" : [
                        "output" : "hip:/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#hip?center_point/x",
                        "operations" : [
                            { "op" : "push", "url" : "Dawn2:#DD-Johon-Body-0xa448199?value" },
                            { "op" : "push", "val" : -0.004436083 },
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "push", "val" : 0.0001148009 },
                            { "op" : "mult" }
                        "output" : "hip:/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#hip?center_point/y",
                        "operations" : [
                            { "op" : "push", "val" : -0.06073761 },
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "push", "val" : 0.00289917 },
                            { "op" : "mult" }
                        "output" : "hip:/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#hip?center_point/z",
                        "operations" : [
                            { "op" : "push", "val" : -3.248002 },
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "push", "val" : 0.9664991 },
                            { "op" : "mult" }
                        "output" : "hip:/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#hip?end_point/x",
                        "operations" : [
                            { "op" : "push", "val" : 0.002514598 },
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "push", "val" : 0.0001842726 },
                            { "op" : "mult" }
                        "output" : "hip:/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#hip?end_point/y",
                        "operations" : [
                            { "op" : "push", "val" : -0.1298752 },
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "push", "val" : 0.04925537 },
                            { "op" : "mult" }
                        "output" : "hip:/data/HiveWire%203D/Dawn%202.0/Base/Dawn2.dsf#hip?end_point/z",
                        "operations" : [
                            { "op" : "push", "val" : -3.083543 },
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "push", "val" : 0.3116791 },
                            { "op" : "mult" }
    Beyond that point in the .dsf file there are all the body parts and beyond that are all the bits of code that have the changes I made to the base.  No more addresses beyond that.
  • Note that these are Duplicate Formulas, not Duplicate IDs.
                        "operations" : [
                            { "op" : "mult" }
                        "operations" : [
                            { "op" : "mult" }
    is oen of them - probably you ran ERC Freeze twice on the same controller, to tweak valuess, without using ERC Bake first to turn the links back into raw values.
    So you've done ERC Freeze on them for at least twice ? Check the screenshot below :  Duplicate formulas are clearly shown there (scroll down to find more), which means the same formulas but pushing different values. That's wrong.
    1053 x 1158 - 204K
    Yup ~ as Richard said, if you want to do multiple ERC Freeze to correct somthing, ERC Bake firstly before ERC Freeze... otherwise you'll get this duplicate formulas issue.
    Ah, I didn't know that.  I redid all the morphs and no issues. I'll have to take a note on the ERC bake thing.  Thanks guys!
