Daz 4.23 Update Broke Fredda
After installing the 4.23 update, Fredda will not load properly. Out of 10 tries, she opened only once correctly after the update. It looks like Daz 8.1 female body is loading without the Fredda morphs. Attached are correct and incorrect snaps.
  • That is unlikely to be an issue in the application update per se - have you checked the log files for errors relating to loading (Help>Troubleshooting>View Log File)?
  • crosswindcrosswind Posts: 9,704
    You may try:
    1) Clear the scene, press F2, Clear DSON Cache Files;
    2) Reload this scene. See if it works.
  • StingerStinger Posts: 324
    Thank you, crosswind!  That worked when I started Daz, cleared the cache, and loaded Fredda from the Content Libraray.  BUT, when I cleared the scene and tried to re-load from the Content Library, she would revert to the unmorphed character.  Right now it looks like I have to restart Daz and clear the cache every time I want to use her. Which isn't bad for a workaround, for now. smiley
    @Richard - Attached is a log file from when she loaded properly, and one when she didn't. Hope it reveals something...?
    txt
    txt
    Fredda Load Log.txt
    275K
    txt
    txt
    Fredda No-Load Log.txt
    73K
    Which log is the one that you got after you correctly loaded Fredda ?
    In the first log, Fredda's character Control property couldn't find Fredda's Head Morph and Body Morph properties ~~ which meant the morphs were not loaded into Property list, that was why you got the 2nd screenshot you posted.
    2552 x 1266 - 363K
    @crosswind the 'Fredda Load Log' was generated when Fredda OK loaded with the morphs.
    I wonder if anyone else out there that owns Fredda could give it a try?  Unfortunately, she's not available in the store anymore... sad
    Of course I have it as Rarestone is a friend of mine. Both Fredda from this store and his Fredda Remaster worked with no issue at all on my side in DS 4.23.
    OK thanks. I might try reinstalling 4.23 when I have a minute.
    Wish I would have nabbed Fredda Remaster when it was available... sad
