Anime Toons and Filatoon Shader Q&A
1101113151632
  • TheNathanParableTheNathanParable Posts: 1,089
    edited October 2024
    Mada said:
    TheNathanParable said:
    Managing to get some nice results with FilaToon. Was even able to get the hair shine effect close to what I wanted, which I hope to explore further with some custom textures. Only thing i'm really struggling with right now are the shadows, they still look blocky if you look close enough.
    Gallery page: https://www.daz3d.com/gallery#image=1351987
    That looks really good, definitely a nice hair shine as well - and that's with a LUT map?
    I'm really happy how well the lines I added on the actual texture map works with the outlines :D
    Not a LUT map, but with a MatCap. I just took one of the painted gloss textures from the hair and plugged it into the MatCap and tweaked the setting. It's a really promising start, will have to see what other effects I can achieve with MatCaps.
    EDIT: Omg, totally didn't realise the school uniform is yours! Yes, the painted outlines and shadows on the outfit look really good, really helps sell the toon look!
    Post edited by TheNathanParable on
  • MadaMada Posts: 2,066
    oops yes I meant a MatCap... still drinking my first coffee of the day lol. That is a great result, looking forward to see what else you come up with experimenting! :D
    Mada, I Love that Hair!!!
  • MarcCCTxMarcCCTx Posts: 947
    edited October 2024
    Working on some old figures.  Can anyone confirm is you reapply a shader, does it resize the black line? I was changing to filadtoon-base to the skin or the hair and it seemed to change the toon-outline's mesh offset to .10 (too small to show.)
    750 x 750 - 307K
    Post edited by MarcCCTx on
  • Hello All!
    I have a Genesis 8 male character that i am quite attached to and want to bring him into the wonderful world of the Toons so I can finally get working on the graphic novel I always wanted to do in the anime style. Does anyone have a suggestion on where I can start to do this? I'm thinking it would be easier to convert the G8M to G9 maybe?
    I don't know what I'm doing. Help? Point me in the right direction to get started. Please.
  • GordigGordig Posts: 10,807
    G9 has no inherent benefit over earlier generations when it comes to the toon shader. All but one of the examples I've posted so far were made with G8 characters.
  • 3Diva3Diva Posts: 12,058
    I'm not sure if it reapplies the default line width, but it likely does. One thing that can help with the jaggy lies though is to select the Filament Draw Options node in the Scene Tab and then in the Parameters Tab select "Anti-Aliasing" and increase the sample count. I bump it up to around 75 for mine and it helps smooth the outline.
    ArtsyDragon said:
    Hello All!
    FilaToon works well with different figures, even the older figures (just have to manually adjust the eyes, usually turning the opacity off on the cornea and/or eye moisture layers).
    edited October 2024
    Definately seems smoother.
    750 x 750 - 277K
    Did you turn mipmaps off already?
    edited October 2024
    On this simple figure, it does not seem to change things. But I did see a big difference on a G8 figure.
    750 x 750 - 294K
  • ArtAngelArtAngel Posts: 2,096
    Love what you guys are doing. Did they use Sakura as the G9Toon base? Looks like a close facsimile.
    Not sure who you're asking but mine are: Kuroneka Mika who is an Anime Doll variation, along with Evo-Girl and Chip (Cookie's guy)
    edited October 2024
    Original Toon Generation girl celebrates being released from the Daz content dungeon!
    1200 x 1600 - 1006K
    Post edited by Wonderland on
  • barbultbarbult Posts: 27,531
    She looks better than ever!
  • PixelPiePixelPie Posts: 382
    edited October 2024
    Oso3D said:
    Here are some of my FilaToon experiments:
     love this robot in toonland!! I'm so happy this works with Robots!!
    Post edited by PixelPie on
    edited October 2024
    Trying to replicate Cookie. I really wish Lady Littlefox would create an exact replica of Cookie for G9 with a regular and a FilaToon version! I think this is fairly close but not quite as cute...
    1200 x 1600 - 1M
  • ArtiniArtini Posts: 10,904
    Cookie looks great, @Wonderland, and you got nice outlines.
    I am still trying to achieve larger and smoother outlines with FilaToon.
    There are some tips in this thread - just need to experiment with them much more.
  •  Smoother outlines probably won't work since it's an effect of an inverted geoshell. Larger ones are achieved by increasing geoshell offset.
    One could probably try very thin and black fine shadows to achieve better blend between the character shadows and the outlines by using a custom matcap map. Matcap maps in this shader are great feature because it's so easy to make custom ones in PS.
  • ArtsyDragonArtsyDragon Posts: 682
    edited October 2024
    Grimm has a fun look with the toon shaders.
    1800 x 1440 - 831K
    1800 x 1440 - 832K
    Post edited by ArtsyDragon on
  • @ArtsyDragon
    You called? laugh
    Just joking, nice render!
  • Grim-Red said:
    @ArtsyDragon
    You called? laugh
    I'm glad you approve. :)
    edited October 2024
    Thanks, I have bumped Anti-Aliasing to 75 and tested it on Chip:
    https://www.daz3d.com/chip
    1200 x 1200 - 183K
    Post edited by Artini on
  • KenYanoKenYano Posts: 145
    We should have this thread pinned.
  • Filatoon is awesome because it also brings life to some older assets you might not be using due to how the resolution contrasts with any newer assets you want to use.  I think anything that encourages usage of legacy content is a HUGE win.  And I also love how the renders are super fast-the holy grail of this kind of art!
    I took a scene that I rendered a while back
    and tooned it.
    Since I only briefly dabbled with Filament before FilaToon was released, I don't know if the emissives not actually casting light onto anything is a limitation of Filament, Daz's implementation of Filament, or FilaToon itself.
  • I think that's a general limitation of Filament. Emissives seem to only generate bloom, not light, so you'll have to use some point lights to compensate.
    edited October 2024
    Under render settings in my first post I'm recommending to turn mipmaps off, but definitely test with both options to get the one that works for you.
    I finally got some time to play with images - Gorgon set :) Dinner!
    1500 x 1950 - 326K
    Post edited by Mada on
  • HighElfHighElf Posts: 373
    It looks like I'm missing a key ingredient. While the distant light works as intended. Spotlights are failing me. I wanted to use the distant light as a rim light while I tried to use two spotlights as key and fill lights.
    I have to go VERY close with the spotlights to even see a tiny bit of illumination. oO I dialed up the intensity to 200% of each of the two lights and used shadow to "deep shadow map" neither the shadows alter nor get I any light on the subject. So what am I doing wrong? I tried scaling Scene Lights on the FillamentDrawNode as well. I cranked it up way over 10 just to see if anything happens, but nothing.
    1920 x 1080 - 931K
