How to fix a Resource Error?
Drogo NazhurDrogo Nazhur Posts: 1,277
I'm getting "a valid PostgreSQL CMS connection could not be established error". How do I fix that? I'm running 4.22 on Windows 11.
Post edited by Drogo Nazhur on
  • Is PostgreSQL running when  Daz Studio or DIM are running? Check Task Manager with More Details on and look at the list of Background preoceses. What security software are you running?
  • Drogo NazhurDrogo Nazhur Posts: 1,277
    I have seven of them running.
    Avast. I haven't made any changes to it recently but this problem started a few days ago.
  • IceCrMnIceCrMn Posts: 2,331
    I ran into this myslef.
    For me
    The problem was I didn't have a Daz Connect folder set in my Content Directory Manager.
    I don't use Connect, so I didn't have the folder set.
    as soon as I set one the error went away and I've never had another since.
    Check to see if you have one, even if you don't use Connect there needs to be one.
    If you need some help setting ths let us know.
    It's really easy to do.
  • Seven or so processes is fairly typical, I am not quite sure why it works that way but it is a sign that PostgreSQL is doing what it should, the issue is in establishing the link with Daz Studio.
    Okay. Thank you.
