Exporting Facial Morphs
Mediahead
I've been attempting to export Snuggles the Toon Bear as an FBX so I could use Acculips in iClone. Although the figure converts well, none of the facial, expression morphs are exported. Any advice?
Have you included expression morphs into Export Rules in FBX export options dialogue?
Thanks for your assistance Crosswind. I thought I added all morphs but how can I ensure the expression morphs are properly exported?
Here's what I've exported:
The export rules seems correct. I tried exporting and importing to Blender as I don't use iClone, the expressions are all there and work. If iClone well supports FBX import, you could've found the morphs somewhere in there.
Thanks Crosswind. If it wasn't for the need to lipsync I would use Blender, His skeleton converted properly using character creator 4's accurig, just not the facial bones or expressions. Hmmm.
I think you also can send a support ticket to reallusion asking for a help... if it still doesn't work for you.
Thank you Crosswind!
