Is there a shorcut to back and forth from main layout to viewport only?
James
I find it's more quicker to work with mulitple viewport, instead of just one.
I imagine of let's say I have the default layout, then I can switch to let's say 3 viewports without any panes. back and forth.
Yes, you can use Activity Bar.
Enable Activity Bar under Windows > Workspace. Press F3, add more Activities under Activities tab. Then configure Layout in each activity with different Viewports / Pane groups setup, as well as Styles.
Then in F3 > Actions tab > Workspace, assign shortcuts to Show Activity 0 ~ 9. Then turn off Enable Activity Bar if you want to have more space... It's up to you. Remember to save your Layout then.
That's a good tip.
Thank you, barbult !
I'm having a bug.
When changing activities pane, daz get shuts down by itself... :(
I'm using 4.23 version.
The previous also the same.
And why the viewport background color on the new activity pane is black instead of grey ?
I've found the solution. Make the changes, shut it down, and open daz again. There's no problem.
Anw, thank you for the information.
