GOZ for Daz 4.23
I downloaded Daz Studio 4.23 but GOZ is not available for download.
There is only GOZ for Public Build but it doesn't work with the main version
Right ~ you can fill a ticket... But older version of GoZ also works in newer DS version, you still can use it for the time being.
Same problem here - but I found a solution: Load your UI from Public build into General with the "Copy_UI_From_Channel" script from brilliant Richard Haseltine (https://www.daz3d.com/forums/discussion/comment/8880326/#Comment_8880326). Now GOZPublic build works in the General release.
Your other post has been removed - please don't post the same thing in multiple places.
You may have only one channel of GoZ installed at one time, so you need to pick beta or general release. I am seeing both in DIM, though I usually keep one hidden to avoid accidentally swapping which is actually installed.
I won't dispute that the author is brilliant and has a name beginning with R, but it isn't me.
