Missing /data/ ... /Genesis8_1Female.dsf
When loading Scene Subsets that I have saved of pre-formed characters, I get the following error:
2024-10-08 11:23:39.861 [WARNING] :: Could not resolve: /data/Daz 3D/Genesis 8/Female 8_1/Genesis8_1Female.dsf
The file is there.  (see attached).
 It finds other stuff in the /data/,,, folders.
for example:
2024-10-08 11:22:51.041 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesLengthUniformUpper.dsf
So I'm note sure what its complaining about.
The figures seem to work...
Anyone seen this?
Any thoughts on resolving?
  • crosswindcrosswind Posts: 9,669
    edited October 2024
    - step 1: open the saved scene subset with Notepad++ (uncompress it if it's compressed), search by Genesis8_1Female.dsf, check if the path is truely correct or not, anything strange ?
    - step 2: press F2, clear DSON cache. Then re-load the subset, see if it works.
    BTW, have you ever installed multiple copies of G8 Starter Essentials package ? for instance, DIM + Daz Connect, or into different Daz Libraries ?
    Post edited by crosswind on
  • I wil try these and see what happens, thanks!
