I screwed up my default settings
Hello,
I don't know exactly what I did but I screwed up my default viewport DAZ settings and it really annoys me as I'm really used to the comfort of default new scene.
As you can see in "default" screenshot,  there is neither longer a default tonemapper nor an environnement created with the "new scene" option. The checkerboard is absent and the background is all gray, I dont have the "plate" that allow me to know where I am. Only this little cross in the center.
I've seen a fix would be to create manually the tonemapper and the environment, which annoys me a bit as default was auto-generated on new scenes before. Plus, I've seen I had to add a backdrop with color in the environement panel and I did (screenshot : black backdrop) but only the frame has the checkeboard on it.
How can I do to have default DAZ options back ? (environnement, tonemapper and the normal viewport)
Thank you !
  • If the Viewport is using the Iray (of Filament) Drawstyle those nodes will be created, or if you do an Iray render - they won't be created if, as in the creenshot, the Viewport if using a non-PBR mode.
    As for the grid, it is there but it matches the background colour and so doesn't show (you would see it if you added a model to the scene and lowered it below floor level). You can set the Viewport background colour in Window>Style>Customise Syle (under 6. Viewports).
  • Very nice, thank you !
