The toolbar on top disappeared
vincentblackwood
Okay, this might be silly, but I swear I've dug through all the options and cannot find a way to bring it back - somehow, for some reason, the toolbar at the top with all sorts of basic functions (new/import/export, add light/camera, navigator/selection tools etc. etc.) just vanished. I can work around it, but since I'm used to having it from the very beginning, this is... not very handy.
Any idea what happened and how to re-enable it? Thanks!
Firstly, is the Status Bar still there ? If so, right-click on the Status Bar, see if Main, Tool are checked... if not, just check them.
Or, if you've ever saved your DS layout, try loading it. And remember to save one if everything is fine later on.
You can also go to Window>Workspace>Customise and in the Activities tab expand the entries [activity name]>Toolbars, then right-click on (I assume) the Main toolbar and select Enable Toolbar
Thanks a lot for both replies - I tried both options, but I swear I could not find either. I just did "Select layout" and basically reloaded it again, and the main toolbar is back (alongside a few things I don't need but that's easy to disable).
