How to Restore Figure Shape
CStrat
Looking for the scripting method to restore figure shape, or for that matter, activate any of the actions in the Edit -> Figure menu.
CStrat
See this sample file (and, if you use its code, make sure you abide by the license terms) http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start#actions
For anyone else interested, the specific action is
And the link Richard provided can help you set up the trigger, for example (and as stated, please use proper attribution since this code comes from the Docs):
I wonder why do I see the whole scripts as one line? This is absolutely unreadable. How to fix it?
Forum limitation/bug, the code tags used to work but now scrunch everything together.
If you "Quote" the post, as if you were going to reply to it, it will display correctly in the "Leave a Comment" input box, and you can read the script there. Just remember to delete instead of "Post Comment" when you are done :)
Great! Thank you.
