Slime effect of dforce costume
morning everyoneangel
I have a question about dforce clothing.
Pose A, the arm is too close to the clothes, direct dforce simulation, the clothes will insert into the arm.
So I adjusted my position, moved my arms away from the fabric of my clothes, simulated the situation, and got a result that I was happy with.
After that, I adjust my arms back to the previous position, and the fabric of the costume will automatically wrap the arms like Slimes. How can you avoid this?
  • GordigGordig Posts: 10,803
    That's not dForce, that's the smoothing modifier.
  • The only way to avoid it is to move the arm out far enough so that it's not intersecting with the shirt.
    thank you ! that's the point !
     You may want to use “Ultimate Simulation Visibility”.
     It may be possible to avoid the phenomenon while maintaining the pose.
    https://www.daz3d.com/forums/discussion/654991/released-ultimate-simulation-visibility-commercial
  • Space JingorohSpace Jingoroh Posts: 176
    edited September 2024
     There is a way to turn off "Mesh Smoothing" on garments, but this may cause problems in other parts of the garment.
    482 x 519 - 61K
    Post edited by Space Jingoroh on
