Adding to Cart…
I made a bowl of beads with Fisio.
Now you got me... OMG what's Fisio? But that's so cool!!!!
Fisio is a Daz Studio plugin. https://www.daz3d.com/fisio-physics-simulator
These beads looked kind of lonely in the bottom of that bowl, so i scaled them up to fill the bowl better.
An exploded dForce necklace can look quite fantastic with some (a lot) of smoothing and a little high resolution.
Test on https://www.daz3d.com/oso-perrito-for-genesis-9
Has not waited to the end of the simulation.
Thanks a lot for the comments, @Fabiana
Another experiment on https://www.daz3d.com/lorez-14-mu-worker-female
Simulates and renders very fast.
I wish I could have posted this up earlier but it's been a busy week...
I LOVE this jewelry set! It's so easy and fun to work with and thank you, THANK YOU, Fabi for including the simulation settings as well, so they drape so nicely. My characters and I are huge fans of your work and I use your products in my art whenever I can. So, I had to render a new piece featuring this set.
I think Fabi's jewlery looks fantastic on everyone, but here's my boy Uri draping himself in several of the chain options. He's also rocking Fabi's EvenGlow jewlery, which I adore for my scifi characters.
Beautiful work as always, Fabiana! I look forward to your next creation.
Your image doesn't show up. Did you delete the attachment? The embedded image will not appear for anyone but you if you delete the attached file.
D'oh! That's exactly what I did. Thanks, Barbult. Fixed it.
Yes, I see it now. It's very interesting.
That didn't take long. In the cart immediately. Is a new forum thread coming?
Of course, right now :D
Thanks for the comments, @Fabiana
Trying to find different combinations is a fun to play with.
Desert selfie with bots
Well, you can't even notice the necklaces on the woman, so I rendered a closer view to prove that they are there.
Very nice, @barbult
That is also something I wonder of.
The chains are so tiny, so one need to do mostly close up renders.
YUP, specially intended for portraits, closeups with realistic look. Or fun renders witht hese scaled to fit whatever :D
Recent use of Venice Med Balls Short on Zahara. I used the Thickener morph on the necklace.
I tried to dForce 3 Venice Tiny Balls necklaces of different lengths at the same time. They exploded. I deleted two of them and kept this one. I thought it looked fabulous! I saved it as a morph so I could use it again.
Here I used my exploded necklace morph at a lower setting.
No, I didn't try the sim without the dress. I did have the hair hidden, though. I think it is possible the the simulation settings got reset from your values to the default values, because at some point I closed DS and reopened it. Either that of the necklaces collided with each other or the model. The very small necklaces were very close to her skin. I didn't make another attempt to make them work, because I was so enthralled with the collision result. I'll try again some other time. I haven't had collision problems in the past.
Amazing result @barbult !
I keep forgetting to apply the "LOAD-FIRST" settings and get an explosion, but I've never let that run to completion to see what I get. Next time I'll be sure to try!
