How to make background all white?
James
I have a room and a window. I just want to make everything outside, from the window looks pure white, the sky, the ground.
How to do that.
You want a solid white, or you want things outside but for them to be white? The former could be done by simply turning off Draw Dome and not having a background prop, or even making the glass invisible if you don't need reflections.
I want outside to be solid white, no sky, no ground, just white.
I tried to use backdrop on environment pane. It becomes white on the outdoor, but looking from inside there are always gradient sky and ground.
put something white there then
Hide the window glass, render, and save as Tiff or PNG - then you wil get an alpha channel or transparency, and can put white behind the render.
