Render Library, Scene Subsets, etc
jmucchiellojmucchiello Posts: 849
How do I tell Daz where I want [Render Library, Scene Subsets, etc] these kinds of thing to Defaul? I don't want them in C:/Users/[user]/Documents/DAZ 3D/Studio/...
There nothing in the Content Directory Manager in Preferences to affect this.
  • You can set the render Library up in the render Library pane, or just switch the render window to use folders instead of libraries using the button to the elft of the library picker 9which will become a folder picker). You can also use File>Save Last Render to save the last render of the session.
    When saving to a folder DS will always open in the last folder used for that type of file (if it exists).
  • That doesn't work when you exit and restart Daz. Or it doesn't seem to. Same probalby Scene Subsets. It always wants to put them in Documents\DAZ 3D\...\My Library\Scene Subsets.
  • And the folder you last saved to still exists? And you are using the File>Save As>Scene Subset command (the + button in the Content Library starts in the current location, if that is in a real folder).
