learning curve
This is the first model I've managed to fit the clothes on properly and pose. I've never done anything like this before, thank you for the free app and models.
  • You can render the result (Render>Render, or cmd/ctrl R, or hit the Render button in the Render Settings pane) then save the image using the button at the bottom of the render pane or File>Save Last Render.
  • GordigGordig Posts: 10,673
    A scene file contains data about which morphs, clothes and materials were used, and will only work correctly if the person opening it owns all the same assets.
