(Released) FK dForce LUXE Chains TWO
Fabiana
Hello Everyone!
Introducing my last product FK dForce LUXE Chains TWO, this time a combination of innovative techniques to get chains and Beads in your necklaces, suitable for all kind of images and figures.
Forget about deformed collars, chains and other details when the autofollow destroys the geometry, enjoy the fun draping over your characters, mix and match with other FK sets and let the imagination flow!
Show me your renders, I love tham all and make me proud seeing the beautiful creations you do with them!
Thank you for coming to see and read.
Fabi
https://www.daz3d.com/fk-dforce-luxe-chains-two-for-genesis-8-81-and-9
Just a few samples here :D
Gorgeous as usual, Fabi! I can't wait to play with these! Your products are always so beautiful.
A G9 render with 4 necklaces of different lengths. I simulated each one individually from memorized pose, current frame. DOF made them a little blurry. I haven't taken time to do any customization yet. I just wanted to post a quick render to get this thread moving.
Another one - this time I used some of the presets to change the beads.
Exquisite, as usual.
Pretty sure the Roasary with ends has been copied from one of my wife's necklaces..
Like it, lots.
Regards,
Richard
Well, I don't know where everyone else is, but I will continue entertaining you with my necklace experiments. In this image I tried an extra short barrel bead necklace with a shape applied. I like it.
Your images are lovely, @barbult - I still haven't had time to install mine, let alone render anything! Too busy buying not using
I guess.
Same here. I hope to do some major installing and maybe even rendering over the weekend. Am enjoying barbult's work in the meantime! The necklaces are just exquisite, as always, and I bought them right aways although I don't need them at all ;-) They're way too pretty to not have. Also, maybe the rosary version can be adapted for a real rosary, with some additions and other positions? That would be cool!
Well I spent a merry evening installing and playing - here's my (not particularly artistic) offering. I really love this product!
Yay! MelanieL, thanks for joining in.
Wait until you see my next one! It's pretty over the top. I've never been good at knowing when enough is enough.
Here it is:
There are so many choices and so many places to hang them,
Adorable! Must check at once whether I own the figure as well. Look how proudly she is presenting her precioussssss ...
So the chains is always parented to the neck?
It is a bit tricky to move them to the designated position.
Are there any tricks to parent and move chains to the desired part of the body automatically?
Oh, that's brilliant!
Thanks for the comments and the tips, @Fabiana.
One more render...
Another pose...
@Artini I like your glowing beads!
I had to move each necklace manually also. It took me half a day to position and simulate all those necklaces on Twiggant.
Toons wear necklaces, too. I added a couple of the prop beads to one. I attached them with rigid follow nodes on the chain.
Thanks a lot, @barbult
Yes, it takes a time to position and simulate all those necklaces.
Thanks to the tips from @Fabiana I am getting faster to parent and position necklaces
where I want them to be.
Your latest "Toons wear necklaces" looks great and one can clearly see the beads.
Thank you very much, @Fabiana
Your tips about unparenting necklaces and parenting to the desired body part
with unchecking "Parent in place" was crucial for me.
Previously I have just used drag and drop necklaces or the other props on the scene hierarchy
which took so much time for me, not to mention position necklaces properly afterwards.
another tip: when doing very close up renders, I always move by small values the necklaces to down and back, it makes all to look more "on the skin".
I have set up these to be moved slowly and sofly so the adjust is exact. Just try it!
Thank you all for your beautiful renders!
