This is actual wardrobe, right?
jmucchiellojmucchiello Posts: 830
https://www.daz3d.com/instyle-women-streetwear-dforce-outfit-for-genesis-9-8-8-1-females
I purchased this. But when I try to use it, I get this error:
I've tried uninstalling it and reinstalling it from DIM. Doesn't help. Redownload and reinstall. Doesn't help.
Post edited by jmucchiello on
  • No - it says ""InStyle"is a companion texture set for InStyle - Women Streetwear dforce outfit for Genesis 9,8 & 8.1 Female(s) by fefecoolyellow."
  • https://www.daz3d.com/instyle-dforce-ruched-halter-top-for-genesis-8-8-1-females-and-genesis-9-fem
    This happens with a lot of Valkyrie items.
    2024-09-11 21:00:30.393 [INFO] :: Begin asset load (merge): /People/Genesis 9/Clothing/-valkyrie-/MAT ISRHTop/05-Halter Top.duf
    2024-09-11 21:00:30.412 [INFO] :: Determining missing assets...
    2024-09-11 21:00:30.417 [ERROR] :: Open File Failed - Could not read file: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
    2024-09-11 21:00:30.423 [ERROR] :: Open File Failed - Could not read file: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
    2024-09-11 21:00:30.428 [ERROR] :: Open File Failed - Could not read file: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
    2024-09-11 21:00:30.434 [ERROR] :: Open File Failed - Could not read file: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
    2024-09-11 21:00:30.441 [ERROR] :: Open File Failed - Could not read file: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
    2024-09-11 21:00:30.446 [ERROR] :: Open File Failed - Could not read file: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
    2024-09-11 21:00:30.448 [WARNING] :: Could not resolve: /data/RainbowLight/dForce Ruched Halter Top(G9F)/Ruched Halter Top/UV Sets/RainbowLight/Base/default.dsf
  • https://www.daz3d.com/creative-for-g9-costume-dress
    This has the same issue
    2024-09-11 21:07:54.231 [INFO] :: Begin asset load (merge): /People/Genesis 9/Clothing/A97/Creative/Creative 04.duf
    2024-09-11 21:07:54.264 [INFO] :: Determining missing assets...
    2024-09-11 21:07:54.271 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.278 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.284 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.294 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.301 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.309 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.317 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.325 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.332 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.339 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
    2024-09-11 21:07:54.346 [ERROR] :: Open File Failed - Could not read file: /data/Antje/G9CostumeDress/Dress/UV Sets/Antje/Base/default.dsf
  • jmucchiellojmucchiello Posts: 830
    edited September 2024
    Why isn't it linked in the store page? Lots of other pages say "you need X to use this" with a picture and a link.
    When I search for the fefecoolyellow item, I can't find it. Why is the store selling addons for items that don't exist in the store?
  • zombietaggerungzombietaggerung Posts: 3,869
    You will likely find the products you are looking for on Renderosity. Recently alot of vendors moved here from there, bringing textures for products that can ONLY be purchased at Renderosity. And since Daz/tafi have a policy of not allowing links to outside stores, the vendors that moved here are not allowed to link to the required products.
    Post edited by zombietaggerung on
  • Yeah, I found some of it at renderosity. But a couple of things I bought add ons for are delisted at renderosity. And they aren't available here either.
    An extremely shitty way to treat customers all around. It's just like if you filter for "Add Ons" nothing comes up. If it did, it would be easier to identify add ons. They should be required to put Add On in the title of the product.
  • Well the ones that are delisted at Renderosity might eventually come here or they may not. I would suggest that if you are still within the 30 day purchase window of the ones you can't find the actual outfit for, just return them for a refund.
  • artxtapartxtap Posts: 179
    i've told daz to label such things with the texture icon. no it is not wardrobe!, it textures.
  • Good news, the dress that I said was delisted on Rendosity has finally arrived at the Daz store and is marked down significantly: https://www.daz3d.com/d-force-costume-dress-for-g9-females
