HDRs
Daniel Barnett
I have a folder of HDRs but they don't show in my content directory. i see the folders but no file. I have a feeling that they are loaded so other way!?! any pointers?
dbb
edit: nothing in user guide!!
Post edited by Daniel Barnett on
I dunno if this will help you but when I use Third party HDRi's I use the render editor to add them to the scene under the eviroments option
see picture below.
Thank you - I thought it might be done in this way but I wasn't sure what menu to select & plug it into!
dbb
You may need to play around with the dome rotation to get the light at the right angle and adding a IDL back light really helps in creating realism too :)
Good luck Like to see what you have when your done :)
You've mentioned this before .. what is an 'IDL' light in Iray? I thought by definition there were were only direct light sources (with the possible exception of a mesh or light with the matte mode applied). Or do you mean a light facing a reflector that then bounces back into the scene? Or is there another way to do it?
I guess I can see the confusion.now.lol thats because I keep mixing up my terms what I mean is IBL (Image Based Lighting) the mix up comes from I use IDL in poser which is means Indrect lighting that is why I keep calling it IDL instead if IBL because thats where i am formilur term using. which IBL would be the proper term so thanks for correcting me once you load the HDRI scene in daz, you point the HDRi light source behind the subject and then add a sun dial present with the hdri, & set it to give you the back light yuo will need to make ajustments to darken or make it more light , at least that is how I have been doing them. and they work really nice that way
Ah, now I get it! Know that setting in Poser well - the long hours of watching the screwy points of red dots as it calculated the lighting. I don't miss that at all!
What HDR image sets do you use that have a sun dial control? That sounds pretty nifty. I'm always turning on the Draw dome feature, and looking at the Iray image render in the Viewport to set the sun direction. Is the sundial control something found in some of the HDRi sets sold in the store?
I like to use what ever I can find there is a good list of frebbies HDRi here at daz. and sometime I find some stock panorama images and make them using photoshop. that is what I did with those Disney copy render i did recently
when you load your scene have the HDR scene light inmage behind the subject your using. this will place the HDR light also bhind the subject. turn the head lamp off on the camera and go to render presets and click preset Sun Dial and when you click it you can set the direction of the light bounce of the HDRi to give that Caustic look to the subject using the defualt "Back HDRi light" . Give me a a little bit and I'll do a quick render of it with the sun behind a girl with and without using that setting.
Okay Please keep in mind I did this very quick and I used the basice settings .. and my graphic cards was rendering these fast i was barely able to get a captuer
1 picture set you HDRi Map
2 picture: rotate your Map to put the light behind the subject, shut off Default Head lamp on your camera your using also
3 Picture. rendering with just basic setting no sundial
4 picture withn out the sun dial just default HDR light and settings
Picture 1 - Add a sundial under the Iray render presets
Picture 2 Adjust Sundial to the location you want for light bounce, in this case i want it behind also the subject
Picture 3 This rendering with sun dial in use with same setting I used without sun dial
Final Render using the Back light it give it a more caustic looks it was hard to capture this live my card was rendering these so fast
you can clearly see how that back sun dial with the HDRi IBL light set in the back gives a diffrent look Keep in Mind this was rendered with just my Graphic card GPU. well anyways thats how I've been doing my renders right or wrong I hope that helps :)
That's very clever! I had assumed the sundial helper was just for Iray's Sun-Sky Only mode. But it looks like setting it even with the Dome (which doesn't use the sun) affects the color temperature and brightness of the environment. Useful in not having to set those things manually.
I thought maybe you were using some HDRi sets that included a "sundial" helper for visualizing and setting the sun direction, rather than relying on Draw mode and watching the Iray render paint in the Viewport. Come to think of it, that's not a bad idea. Would take a lot of the guesswork out of using some of these HDR images...
I never knew what that sundial was even for before chris told me..lol That painting idea would be like the old skydomes y'll have to work that one out for sure now..lol
Ivy - thank you for thr info!!! I'll be trying this again this weekend. I really screwed things up - all I'm getting is a black box when I render so I'll need sometime to step thing backwards to see what I did!!
Thank you!
dbb
