dForce Modifier
I am struggling. I thought that it was possible to add a dForce modifier to a clothing item that doesn't have one. I have bumbled through every menu that I can find and the option doesn't seem to be anywhere.
What am I missing? Was this changed in an update?
Any help is appreciated.
Thank you.
  • crosswindcrosswind Posts: 9,704
    No change if you use DS Pro version... still in DS menu: Edit > Figure > Geometry > Add dForce Modifier: ...
  • I do not have that option appearing in my menus any longer.
  • When I open the Edit menu this is what I see:
    2845 x 1191 - 673K
  • Try reloading your layout (Window>Workspace>Select Layout), there are a lot of oddities in the menu structure in that screenshot.
  • barbultbarbult Posts: 26,458
    Maybe update and merge menus is needed.
    I was thinking reloading the layout would do that, but since I was sent a reminder of the command probably not.
    I appreciate the suggestion but I don't know what "merge menus" means and I'm pretty sure that I'm updated to the latest version. Could you please share a little more context for how to do what you are suggesting? Thank you.
  • Window>Workspace>Update and Merge Menus will update the menus to add new features without changing the current layout (loading a layout will update, but will also change the layout - which may or may not be desirable for you).
