Script For Ultimate Pose Master?
Hi Folks,
After a lot of reading and searching I have located this script in the relevant windows folder and got it working by running it from there but I want to be able to run it from within Daz itself. However when I go to the scripts folder where all my assets are, the script for this product does not exist, I can see others for other products though.
I feel I'm missing something obvious but the instructions I've read that came with the product all seem to assume I should already know how to do this and don't have a section on how to add the script to Daz.
In which pane are you looking?
Ahhhhh, of course, I was looking under Smart Content and I should have been looking under Content Library. Thank you sooo much!
That is a little confusing though and has caught me out before, I should have remembered. Is there a reason why not all stuff bought from the store and installed using install manager doesn't appear under smart content?
It may be that the emtadata is not correctly set up, but if this happens often it might also be a local issue (in particular, if you happen to close DS and start DIM it is possible that the database will be mid-shutdown when DIM starts and as a result it won't be available when installing the content, and of course there is always the possibility of over-eager security software)
Ah okay, I'll check it out, thanks for your help.
