Genesis 8 or 9?
currently I'm using Genesis 8, but when I browse shop there's a many product that actually looks really good and it's only for Genesis 9
it makes me wonder should I move on to Genesis 9
but then again even if I try to move on to new genesis so many product that I got only works with Genesis 8
it means that I have to buy all the stuff again for Genesis 9
how do you deal with this situation?  do you just drop certain generation completely?
or do you use both generation same time?
  • GordigGordig Posts: 10,673
    You do whatever is appropriate for your circumstances. It's worth considering that generations are backward-compatible but not forward, meaning that a G8 product is more likely to work well with G9 than a G9 product is to work well with G8. Products like morphs, geoshells and materials won't work directly, although there are ways to adapt some of them to G9. Clothes, on the other hand, seem to autofit well to G9.
    I'm still on G8 myself, because I can't afford to invest very much into G9, and also haven't spent enough time with G9 to see how much I like working with it.
  • LeanaLeana Posts: 12,972
    Why should using G9 mean you have to drop G8 (or any other generation) entirely? It's not like G8 will stop working once you install G9...
    If you want to use G9 I would suggest progressively building your G9 library (starting with free stuff) and including it in some of your work. Take advantages of big sales to get good deals on the basics.
    It may or may not become your main figure after some time.
  • MaxWell It's up to you to decide which Genesis figures you like to work with.
    I got a bit of every generation, Genesis 1, 2, 3, 8 and 9.
    I am using G9 because I like it the characters, but it does not mean the previous generations are no good; so take your time and you can build your library.
  • HylasHylas Posts: 5,278
    edited September 2024
    Everybody has to decide what makes the most sense for themselves. I only use G8.1 and content that is compatible with G8.1. That includes some G9 content (auto-fit, conversions). But there's lots of content that looks real good but I will not buy it because it's not compatible with G8.1.
    Post edited by Hylas on
  • (1) I use multiple generations of models, and have since Genesis (One).
    (2) I don't know why people stop using previous generations. I suspect it's an irrational belief that because the integer after the name of the product has changed, previously released items are somehow unusably obsolete.  There is a big difference between being technically obsolete (clearly inferior and more difficult to work with) and being deprecated or just obsolescent from a marketing perspective.
    (3) I think relatively new users would find content from Genesis 3 easiest to use: Pre-dForce, but with Iray materials.  The content is quite cheap now.
  • Roman_K2Roman_K2 Posts: 1,275
    G9 is *a lot* more complicated. Try doing some ballet or martial arts poses and expressions from scratch. Just saying!
  • ty everyone !!!!!
  • yarajputyarajput Posts: 0
    Hi Maxwell, there are various converters for switching between generations. You can convert characters, clothing, and poses as needed. Some videos on YouTube show you how to convert items manually. Note that these instructions are a bit time-consuming compared to scripts that somebody is selling, or if you decide to make your own scripts. I prefer Victoria 7's more model-like look over Victoria 8's girl-next-door-like look; however, I prefer the material and functionality of Victoria 8 and Generation 8. As I own Victoria 7, 8, and 9, I converted all Victoria's 7 shaping settings to GF8 character morphs using XTransfer—Genesis 3 to Genesis 8 Converter. Now, I can use the materials from my Victoria 8, such as skin, eyes, tear ducts, etc., and still have the look of the Victoria 7 Shape. Older hair and clothes should auto-fit with some fine-tuning. I recently purchased Generation 3 and Generation 8 characters and items from the bargain bins in Daz Shop, as I have the tools to convert them if needed. You can even convert G9 characters and items to G8 if you don't want to move to G9. Look up converters and transfer products from RSSY and Zev0. Best of luck
