surfaces tab issue
I am not sure how I did it, but now in the surfaces tab everything, and I mean everything shows. I checked and show hidden properties is not selected. I have not clue what I have done, but I would like to undo it so I only see what is actually being used. Like, normally, if there is no emission or displacement, I see the slot for emission but nothing below that. Now I see it even if there is nothing functioning? Any help appreciated.
  • Which shader is applied? Top-left in the Editor tab of the Sufaces pane
  • ChoppskiChoppski Posts: 636
    Depends on what I am using, but the current one says lray uber (MDL). If I hit currently used then I only see what is used, but if I select any specific surface, it goes back to showing every sub file for each element.
  • Richard HaseltineRichard Haseltine Posts: 109,292
    edited August 2024
    Do you have Show Sub Items checked at bottom-left of the Surfaces pane? I didn't understand the issue proeprly from the first post.
    Hi, yes I did have show sub items. However, I did NOT have show hidden properties selected. Once I did, all the stuff I didn't want to see went away. So I guess that did it, but that is the opposite of the parameters tab where show hidden properties gives you all the stuff you normally cannot see. odd.
  • Show Hidden Properties is about items that have been made hidden, so they don't show at all. Show Sub-Items is about showing items in sub-folders of the current folder, but only if they would be visible when the sub-folder itself was selected. There is no real conenction between the two.
