Different resolution of normal maps for different body parts ?
HenryHenry Posts: 28
edited August 2024 in Daz Studio Discussion
Hi,everyone,I'm trying to edit normal map using substance 3D painter (as a newbee method instead of baking it), and I found that different body parts like torso and arms has different resolution of normal map (just as you can see in the image). It looks totally different even I using the same brush drawing on it . Can this be fix? Or that just because different body part have different UV stretch problem ? Please help,much thanks!
Post edited by Henry on
  • It is essentially the UVs - there isn't a perfect way to map anything much more complex than a box, and humans are much more complex than a box.
  • crosswindcrosswind Posts: 10,276
    I was bold to say that people even could find this sort of issue on every G8/G9 character product ~~
    Maybe you can firstly check this thread in which we ever discussed some relevance: https://www.daz3d.com/forums/discussion/697141/udim-seam-genesis-8-in-substance-3d-painter
  • HenryHenry Posts: 28
    Thank you Richard, yes after offered all my attempts trying to make it right. I realized that it's the UV problem, what a shame.
    Thanks mate. I've dived into the thread you concerned, it seems that the only way havm't tried is baking texture from high model, I will start from there. The problem I mentioned can't be fix by editing texture I guess.Thank you anyway.
    No problem ~ Yea, as for baking HD mesh, since I found those non-seamless issues on Daz Originals characters as well as on other PA's character, I really didn't think that should be the workflow when they make textures, so I gave it up.
    But anyway, pls feel to try and let us know the result if possible. Thank you man !
    edited August 2024
    Yep,I've tried to bake from high poly model, and it seems that texture generated from high model can solve seam problem in somehow( see the images I attached, those are normal maps I generated from high poly, though not as fine as I  posted before ). On the other hand, we still can't get rid of those blury problem on the edge. It seems that UV stretch causing these problem, too bad.
    1180 x 664 - 85K
    803 x 569 - 69K
    Thank you for the feedback !  I still don't think that is UV stretching issue 'cause the figure just has the default A-Pose. It should be just an issue of different texel resoluions on the seams ~~ it's a shame.
