SY Hat and Hair Helper Genesis 8: Cheek 01/02 L morphs are not applied on the left cheek
Hello,
I'm speaking about this product by @Sickleyield: https://www.daz3d.com/sy-hat-and-hair-helper-genesis-8
I installed it with DIM and used it with Daz 4.21 and the last public beta, observing the same problem in both versions.
To test it, I loaded a G8.1F and a G8.1M figures, then I loaded their respective helpers before loading hairs with the helper selected (it was a pain to find a G8M hair who reacted to the cheek morphs…). Then I dialed the two cheek morphs and here are the results: change happen on the right side of the face.
G8F Cheek L morphs
G8F Cheek R morphs
G8M Cheek L morphs
G8M Cheek R morphs
I tested every other morphs related to either left and right and as far as I can seen, they are applied to the intended side of the face, and in the vicinity of where they should be applied according to their name.
I also check if it was something as simple as the Cheek L morphs calling the Cheek R files, but nope, they are calling Cheek L 01.dsf and Cheek L 02.dsf. I didn't open these dsf files, it would likely be gibberish to my untrained eyes.
Can someone who has this product check if they observe the same behavior before I open a ticket ?
I vaguely rememeber this issue, ha ~ Let me check...
Yes, I think two Cheek L morphs were wrongly imported on Right side by SY. Unfortunately, this helper's geometry is not symmetrical in DS, I had no way to fix it by using Mirroring or Attenuate options. So some sculpting had to be needed ~~
Anyway, pls submit a ticket ...
Ah that's too bad: I hoped a fix was possible on my end while waiting for an official fix.
I opened a ticket.
