IRAY can't render
kyoreona
I'm in some trouble ,sir
Today, I previewed a scene with IRAY and stayed in a smooth shaded mode.
I tried to render directly with CTRL+R, and after a few seconds, it was over, leaving me with a name for the resulting rendered file, which was a completely blank PNG.
I restarted the software, imported a simple notebook model into the scene, IRAY preview works fine, but CTRL+R for rendering, also quickly finished, got a blank PNG file.
I noticed an alarm in the LOG :
[WARNING] :: QColor::setRgb: RGB parameters out of range
here is the log
2024-08-18 00:09:16.906 [WARNING] :: QColor::setRgb: RGB parameters out of range
2024-08-18 00:09:16.924 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge_Light.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
2024-08-18 00:09:16.925 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
2024-08-18 00:09:16.928 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Screen.jpg", no selector, pixel type "Rgb", 2500x1600x1 pixels, 1 miplevel.
2024-08-18 00:09:16.931 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Keyboard 2.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
2024-08-18 00:09:16.938 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Lense.jpg", no selector, pixel type "Rgb", 275x275x1 pixels, 1 miplevel.
2024-08-18 00:09:16.940 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
2024-08-18 00:09:16.942 Iray [INFO] - TRAV:DATABASE :: 1.0 TRAV db progr: Traversing scene.
2024-08-18 00:09:16.959 Iray [INFO] - TRAV:DATABASE :: 1.0 TRAV db info : Traversing scene took 0.017 s.
2024-08-18 00:09:16.960 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry contexts.
2024-08-18 00:09:16.961 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2024-08-18 00:09:16.961 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2024-08-18 00:09:16.965 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
2024-08-18 00:09:16.965 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 169 k triangles, 1 instance yielding 169 k triangles) took 0.006 s
2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating section objects.
2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2024-08-18 00:09:16.973 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 26 textures, 0 lambdas (0 unique)
2024-08-18 00:09:16.973 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (1 light source with 188 triangles, 1 instance) took 0.000 s
2024-08-18 00:09:16.973 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled material code.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled environment code.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating material textures.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment textures.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating BSDFs.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating volumes.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2024-08-18 00:09:16.978 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled backplate code.
2024-08-18 00:09:16.978 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate textures.
2024-08-18 00:09:16.978 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2024-08-18 00:09:16.982 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2024-08-18 00:09:16.982 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2024-08-18 00:09:16.987 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2024-08-18 00:09:16.987 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering.
2024-08-18 00:09:16.989 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX for CUDA device 0
2024-08-18 00:09:17.217 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2024-08-18 00:09:17.217 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti)
2024-08-18 00:09:17.218 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2024-08-18 00:09:17.218 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Processing scene...
2024-08-18 00:09:17.331 Iray [INFO] - IRAY:RENDER :: 1.6 IRAY rend info : Importing lights for motion time 0
2024-08-18 00:09:17.331 Iray [INFO] - IRAY:RENDER :: 1.6 IRAY rend info : Initializing light hierarchy.
2024-08-18 00:09:17.334 Iray [INFO] - IRAY:RENDER :: 1.6 IRAY rend info : Light hierarchy initialization took 0.002 s
2024-08-18 00:09:17.361 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Scene processed in 0.143s
2024-08-18 00:09:17.363 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 28.016 MiB for frame buffer
2024-08-18 00:09:17.363 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
2024-08-18 00:09:17.363 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Optimizing for cooperative usage (performance could be sacrificed)
2024-08-18 00:09:17.497 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iteration after 0.271 s.
2024-08-18 00:09:17.502 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2024-08-18 00:09:17.543 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00002 iterations after 0.313 s.
2024-08-18 00:09:17.581 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00003 iterations after 0.351 s.
2024-08-18 00:09:17.621 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00004 iterations after 0.390 s.
2024-08-18 00:09:17.655 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00005 iterations after 0.424 s.
2024-08-18 00:09:17.693 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00006 iterations after 0.462 s.
2024-08-18 00:09:17.729 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00007 iterations after 0.498 s.
2024-08-18 00:09:17.768 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00008 iterations after 0.536 s.
2024-08-18 00:09:17.826 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00010 iterations after 0.595 s.
2024-08-18 00:09:17.912 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00013 iterations after 0.681 s.
2024-08-18 00:09:17.998 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00016 iterations after 0.767 s.
2024-08-18 00:09:18.075 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00019 iterations after 0.844 s.
2024-08-18 00:09:18.159 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00022 iterations after 0.929 s.
2024-08-18 00:09:18.236 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00025 iterations after 1.004 s.
2024-08-18 00:09:18.317 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00028 iterations after 1.085 s.
2024-08-18 00:09:18.468 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00034 iterations after 1.237 s.
2024-08-18 00:09:18.670 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00042 iterations after 1.439 s.
2024-08-18 00:09:18.869 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00050 iterations after 1.638 s.
2024-08-18 00:09:18.954 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2024-08-18 00:09:18.954 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): 50 iterations, 0.384s init, 1.516s render
2024-08-18 00:09:22.290 [VERBOSE] :: Requesting current notification data...
2024-08-18 00:09:22.290 [VERBOSE] :: Requesting default notification data...
2024-08-18 00:09:23.651 [INFO] :: Clearing the scene...
2024-08-18 00:09:23.708 [INFO] :: *** Scene Cleared ***
2024-08-18 00:09:23.734 [INFO] :: Resetting view cameras...
2024-08-18 00:09:25.944 [INFO] :: Prepare asset load (open): /Props/Z My Favourite Gadgets/Z MFG Laptop.duf
2024-08-18 00:09:25.944 [INFO] :: Locking viewport redraw...
2024-08-18 00:09:25.944 [INFO] :: Viewport redraw locked.
2024-08-18 00:09:25.988 [VERBOSE] :: Native format content directories: 207
2024-08-18 00:09:25.988 [VERBOSE] :: Poser format content directories: 4
2024-08-18 00:09:25.988 [VERBOSE] :: Other import format content directories: 0
2024-08-18 00:09:25.988 [INFO] :: Begin asset load (open): /Props/Z My Favourite Gadgets/Z MFG Laptop.duf
2024-08-18 00:09:25.996 [INFO] :: Clearing the scene...
2024-08-18 00:09:26.004 [INFO] :: *** Scene Cleared ***
2024-08-18 00:09:26.004 [INFO] :: Determining missing assets...
2024-08-18 00:09:26.027 [INFO] :: Setting textures...
2024-08-18 00:09:26.028 [INFO] :: Scanning for addons...
2024-08-18 00:09:26.032 [INFO] :: Creating node geometry...
2024-08-18 00:09:26.035 [INFO] :: Creating UV sets...
2024-08-18 00:09:26.035 [INFO] :: Creating materials...
2024-08-18 00:09:26.090 [INFO] :: Resolving legacy figures...
2024-08-18 00:09:26.090 [INFO] :: Sorting property groups...
2024-08-18 00:09:26.090 [INFO] :: Setting up follow targets...
2024-08-18 00:09:26.090 [INFO] :: Finished asset load (open): 0m 0.102s - /Props/Z My Favourite Gadgets/Z MFG Laptop.duf
2024-08-18 00:09:26.121 [INFO] :: Unlocking viewport redraw...
2024-08-18 00:09:26.121 [INFO] :: Viewport redraw unlocked.
2024-08-18 00:09:26.197 [INFO] :: Loaded image: Grunge_Light.png
2024-08-18 00:09:26.200 [INFO] :: Loaded image: Lense.jpg
2024-08-18 00:09:26.210 [INFO] :: Loaded image: Grunge.png
2024-08-18 00:09:26.231 [INFO] :: Loaded image: Laptop Keyboard 2.png
2024-08-18 00:09:26.281 [INFO] :: Loaded image: Laptop Screen.jpg
2024-08-18 00:09:27.457 [WARNING] :: QColor::setRgb: RGB parameters out of range
2024-08-18 00:09:27.477 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge_Light.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
2024-08-18 00:09:27.478 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
2024-08-18 00:09:27.481 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Screen.jpg", no selector, pixel type "Rgb", 2500x1600x1 pixels, 1 miplevel.
2024-08-18 00:09:27.484 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Keyboard 2.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
2024-08-18 00:09:27.491 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Lense.jpg", no selector, pixel type "Rgb", 275x275x1 pixels, 1 miplevel.
2024-08-18 00:09:27.493 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
2024-08-18 00:09:27.494 Iray [INFO] - TRAV:DATABASE :: 1.0 TRAV db progr: Traversing scene.
2024-08-18 00:09:27.512 Iray [INFO] - TRAV:DATABASE :: 1.0 TRAV db info : Traversing scene took 0.017 s.
2024-08-18 00:09:27.513 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry contexts.
2024-08-18 00:09:27.513 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2024-08-18 00:09:27.513 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2024-08-18 00:09:27.517 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
2024-08-18 00:09:27.517 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2024-08-18 00:09:27.525 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 169 k triangles, 1 instance yielding 169 k triangles) took 0.008 s
2024-08-18 00:09:27.525 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2024-08-18 00:09:27.525 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating section objects.
2024-08-18 00:09:27.526 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2024-08-18 00:09:27.527 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 26 textures, 0 lambdas (0 unique)
2024-08-18 00:09:27.527 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (1 light source with 188 triangles, 1 instance) took 0.000 s
2024-08-18 00:09:27.527 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2024-08-18 00:09:27.531 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled material code.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled environment code.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating material textures.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment textures.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating BSDFs.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating volumes.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating compiled backplate code.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate textures.
2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2024-08-18 00:09:27.537 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2024-08-18 00:09:27.537 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2024-08-18 00:09:27.545 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2024-08-18 00:09:27.545 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering.
2024-08-18 00:09:27.548 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX for CUDA device 0
2024-08-18 00:09:27.761 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2024-08-18 00:09:27.761 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti)
2024-08-18 00:09:27.761 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2024-08-18 00:09:27.762 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Processing scene...
2024-08-18 00:09:27.868 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Importing lights for motion time 0
2024-08-18 00:09:27.868 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Initializing light hierarchy.
2024-08-18 00:09:27.871 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Light hierarchy initialization took 0.003 s
2024-08-18 00:09:27.903 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Scene processed in 0.142s
2024-08-18 00:09:27.908 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 28.016 MiB for frame buffer
2024-08-18 00:09:27.908 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
2024-08-18 00:09:27.908 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Optimizing for cooperative usage (performance could be sacrificed)
2024-08-18 00:09:28.092 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iteration after 0.321 s.
2024-08-18 00:09:28.097 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2024-08-18 00:09:28.127 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00002 iterations after 0.352 s.
2024-08-18 00:09:28.151 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00003 iterations after 0.375 s.
2024-08-18 00:09:28.175 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00004 iterations after 0.399 s.
2024-08-18 00:09:28.199 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00005 iterations after 0.423 s.
2024-08-18 00:09:28.221 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00006 iterations after 0.446 s.
2024-08-18 00:09:28.245 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00007 iterations after 0.470 s.
2024-08-18 00:09:28.269 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00008 iterations after 0.494 s.
2024-08-18 00:09:28.296 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00009 iterations after 0.521 s.
2024-08-18 00:09:28.330 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00011 iterations after 0.555 s.
2024-08-18 00:09:28.389 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00015 iterations after 0.614 s.
2024-08-18 00:09:28.486 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00022 iterations after 0.710 s.
2024-08-18 00:09:28.581 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00029 iterations after 0.806 s.
2024-08-18 00:09:28.680 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00036 iterations after 0.905 s.
2024-08-18 00:09:28.777 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00043 iterations after 1.001 s.
2024-08-18 00:09:28.829 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2024-08-18 00:09:28.829 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): 43 iterations, 0.372s init, 0.844s render
2024-08-18 00:09:29.738 [VERBOSE] :: Requesting current notification data...
2024-08-18 00:09:29.738 [VERBOSE] :: Requesting default notification data...
2024-08-18 00:09:30.462 [INFO] :: Clearing the scene...
2024-08-18 00:09:30.512 [INFO] :: *** Scene Cleared ***
I think I found the trigger.
After I rebooted the software, the tests worked fine.
But I only have to load my project once, and the above problem occurs. Even if you shut down the project and re-import a simple item, there will be problems.
But once you reboot the software, it's back to normal.
RGB parameters out of range doesn't matter and most of people have this message.
Your DS version ? and are you using Nvidia Studio driver ? and Version ?
4.22.0.16
4060 TI 16G
Hi, I tried it again this morning, checking the models in the scene one by one.
Finally, the problem is a model of hair.
【Rose Hair for Genesis 3 and 8 Female(s)】
delete the hair, save it, and open the whole scene without a problem.
But this hair model, I have used it before, and there is no problem. It's officially sold by DAZ.
When I tried to import this hair model separately for IRAY preview, the above mentioned problem occurred and I stayed in this shader mode all the time.
At this point, I'm sure the source of the problem is it, but I don't know what the cause of the problem is.
Ah ~~ this is a hair product from OOT, which used to have a hair blending shader issue when using DS 4.21+. http://docs.daz3d.com/doku.php/public/read_me/index/56463/start
Have you updated this hair product via DIM ?
