IRAY can't render
I'm in some trouble ,sir
Today, I previewed a scene with IRAY and stayed in a smooth shaded mode.
I tried to render directly with CTRL+R, and after a few seconds, it was over, leaving me with a name for the resulting rendered file, which was a completely blank PNG.
I restarted the software, imported a simple notebook model into the scene, IRAY preview works fine, but CTRL+R for rendering, also quickly finished, got a blank PNG file.
I noticed an alarm in the LOG :
[WARNING] :: QColor::setRgb: RGB parameters out of range
  • kyoreonakyoreona Posts: 213
    here is the log
    2024-08-18 00:09:16.906 [WARNING] :: QColor::setRgb: RGB parameters out of range
    2024-08-18 00:09:16.924 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge_Light.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
    2024-08-18 00:09:16.925 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
    2024-08-18 00:09:16.928 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Screen.jpg", no selector, pixel type "Rgb", 2500x1600x1 pixels, 1 miplevel.
    2024-08-18 00:09:16.931 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Keyboard 2.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
    2024-08-18 00:09:16.938 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Lense.jpg", no selector, pixel type "Rgb", 275x275x1 pixels, 1 miplevel.
    2024-08-18 00:09:16.940 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2024-08-18 00:09:16.942 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2024-08-18 00:09:16.959 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 0.017 s.
    2024-08-18 00:09:16.960 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
    2024-08-18 00:09:16.961 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2024-08-18 00:09:16.961 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2024-08-18 00:09:16.965 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2024-08-18 00:09:16.965 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 169 k triangles, 1 instance yielding 169 k triangles) took 0.006 s
    2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2024-08-18 00:09:16.971 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2024-08-18 00:09:16.973 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 26 textures, 0 lambdas (0 unique)
    2024-08-18 00:09:16.973 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 188 triangles, 1 instance) took 0.000 s
    2024-08-18 00:09:16.973 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2024-08-18 00:09:16.977 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2024-08-18 00:09:16.978 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2024-08-18 00:09:16.978 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2024-08-18 00:09:16.978 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2024-08-18 00:09:16.982 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2024-08-18 00:09:16.982 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2024-08-18 00:09:16.987 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2024-08-18 00:09:16.987 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2024-08-18 00:09:16.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2024-08-18 00:09:17.217 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2024-08-18 00:09:17.217 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti)
    2024-08-18 00:09:17.218 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2024-08-18 00:09:17.218 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Processing scene...
    2024-08-18 00:09:17.331 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : Importing lights for motion time 0
    2024-08-18 00:09:17.331 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : Initializing light hierarchy.
    2024-08-18 00:09:17.334 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : Light hierarchy initialization took 0.002 s
    2024-08-18 00:09:17.361 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Scene processed in 0.143s
    2024-08-18 00:09:17.363 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 28.016 MiB for frame buffer
    2024-08-18 00:09:17.363 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
    2024-08-18 00:09:17.363 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Optimizing for cooperative usage (performance could be sacrificed)
    2024-08-18 00:09:17.497 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 0.271 s.
    2024-08-18 00:09:17.502 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2024-08-18 00:09:17.543 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 0.313 s.
    2024-08-18 00:09:17.581 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 0.351 s.
    2024-08-18 00:09:17.621 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00004 iterations after 0.390 s.
    2024-08-18 00:09:17.655 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 0.424 s.
    2024-08-18 00:09:17.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00006 iterations after 0.462 s.
    2024-08-18 00:09:17.729 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 0.498 s.
    2024-08-18 00:09:17.768 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00008 iterations after 0.536 s.
    2024-08-18 00:09:17.826 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00010 iterations after 0.595 s.
    2024-08-18 00:09:17.912 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00013 iterations after 0.681 s.
    2024-08-18 00:09:17.998 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00016 iterations after 0.767 s.
    2024-08-18 00:09:18.075 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00019 iterations after 0.844 s.
    2024-08-18 00:09:18.159 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00022 iterations after 0.929 s.
    2024-08-18 00:09:18.236 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00025 iterations after 1.004 s.
    2024-08-18 00:09:18.317 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00028 iterations after 1.085 s.
    2024-08-18 00:09:18.468 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00034 iterations after 1.237 s.
    2024-08-18 00:09:18.670 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00042 iterations after 1.439 s.
    2024-08-18 00:09:18.869 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00050 iterations after 1.638 s.
    2024-08-18 00:09:18.954 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2024-08-18 00:09:18.954 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): 50 iterations, 0.384s init, 1.516s render
    2024-08-18 00:09:22.290 [VERBOSE] :: Requesting current notification data...
    2024-08-18 00:09:22.290 [VERBOSE] :: Requesting default notification data...
    2024-08-18 00:09:23.651 [INFO] :: Clearing the scene...
    2024-08-18 00:09:23.708 [INFO] :: *** Scene Cleared ***
    2024-08-18 00:09:23.734 [INFO] :: Resetting view cameras...
    2024-08-18 00:09:25.944 [INFO] :: Prepare asset load (open): /Props/Z My Favourite Gadgets/Z MFG Laptop.duf
    2024-08-18 00:09:25.944 [INFO] :: Locking viewport redraw...
    2024-08-18 00:09:25.944 [INFO] :: Viewport redraw locked.
    2024-08-18 00:09:25.988 [VERBOSE] :: Native format content directories: 207
    2024-08-18 00:09:25.988 [VERBOSE] :: Poser format content directories: 4
    2024-08-18 00:09:25.988 [VERBOSE] :: Other import format content directories: 0
    2024-08-18 00:09:25.988 [INFO] :: Begin asset load (open): /Props/Z My Favourite Gadgets/Z MFG Laptop.duf
    2024-08-18 00:09:25.996 [INFO] :: Clearing the scene...
    2024-08-18 00:09:26.004 [INFO] :: *** Scene Cleared ***
    2024-08-18 00:09:26.004 [INFO] :: Determining missing assets...
    2024-08-18 00:09:26.027 [INFO] :: Setting textures...
    2024-08-18 00:09:26.028 [INFO] :: Scanning for addons...
    2024-08-18 00:09:26.032 [INFO] :: Creating node geometry...
    2024-08-18 00:09:26.035 [INFO] :: Creating UV sets...
    2024-08-18 00:09:26.035 [INFO] :: Creating materials...
    2024-08-18 00:09:26.090 [INFO] :: Resolving legacy figures...
    2024-08-18 00:09:26.090 [INFO] :: Sorting property groups...
    2024-08-18 00:09:26.090 [INFO] :: Setting up follow targets...
    2024-08-18 00:09:26.090 [INFO] :: Finished asset load (open): 0m 0.102s - /Props/Z My Favourite Gadgets/Z MFG Laptop.duf
    2024-08-18 00:09:26.121 [INFO] :: Unlocking viewport redraw...
    2024-08-18 00:09:26.121 [INFO] :: Viewport redraw unlocked.
    2024-08-18 00:09:26.197 [INFO] :: Loaded image: Grunge_Light.png
    2024-08-18 00:09:26.200 [INFO] :: Loaded image: Lense.jpg
    2024-08-18 00:09:26.210 [INFO] :: Loaded image: Grunge.png
    2024-08-18 00:09:26.231 [INFO] :: Loaded image: Laptop Keyboard 2.png
    2024-08-18 00:09:26.281 [INFO] :: Loaded image: Laptop Screen.jpg
    2024-08-18 00:09:27.457 [WARNING] :: QColor::setRgb: RGB parameters out of range
    2024-08-18 00:09:27.477 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge_Light.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
    2024-08-18 00:09:27.478 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Grunge.png", no selector, pixel type "Rgb_16", 512x512x1 pixels, 1 miplevel.
    2024-08-18 00:09:27.481 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Screen.jpg", no selector, pixel type "Rgb", 2500x1600x1 pixels, 1 miplevel.
    2024-08-18 00:09:27.484 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Laptop Keyboard 2.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
    2024-08-18 00:09:27.491 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "F:\3D\A-collection\A_world\CLOUD\! 01\34\Z My Favourite Gadge Props\Runtime\Textures\Z My Favourite Gadgets\Lense.jpg", no selector, pixel type "Rgb", 275x275x1 pixels, 1 miplevel.
    2024-08-18 00:09:27.493 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2024-08-18 00:09:27.494 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2024-08-18 00:09:27.512 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 0.017 s.
    2024-08-18 00:09:27.513 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
    2024-08-18 00:09:27.513 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2024-08-18 00:09:27.513 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2024-08-18 00:09:27.517 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2024-08-18 00:09:27.517 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2024-08-18 00:09:27.525 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 169 k triangles, 1 instance yielding 169 k triangles) took 0.008 s
    2024-08-18 00:09:27.525 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2024-08-18 00:09:27.525 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2024-08-18 00:09:27.526 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2024-08-18 00:09:27.527 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 26 textures, 0 lambdas (0 unique)
    2024-08-18 00:09:27.527 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 188 triangles, 1 instance) took 0.000 s
    2024-08-18 00:09:27.527 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2024-08-18 00:09:27.531 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2024-08-18 00:09:27.532 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2024-08-18 00:09:27.537 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2024-08-18 00:09:27.537 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2024-08-18 00:09:27.545 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2024-08-18 00:09:27.545 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2024-08-18 00:09:27.548 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2024-08-18 00:09:27.761 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2024-08-18 00:09:27.761 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti)
    2024-08-18 00:09:27.761 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2024-08-18 00:09:27.762 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Processing scene...
    2024-08-18 00:09:27.868 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2024-08-18 00:09:27.868 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2024-08-18 00:09:27.871 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 0.003 s
    2024-08-18 00:09:27.903 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Scene processed in 0.142s
    2024-08-18 00:09:27.908 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 28.016 MiB for frame buffer
    2024-08-18 00:09:27.908 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
    2024-08-18 00:09:27.908 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Optimizing for cooperative usage (performance could be sacrificed)
    2024-08-18 00:09:28.092 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 0.321 s.
    2024-08-18 00:09:28.097 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2024-08-18 00:09:28.127 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 0.352 s.
    2024-08-18 00:09:28.151 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 0.375 s.
    2024-08-18 00:09:28.175 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00004 iterations after 0.399 s.
    2024-08-18 00:09:28.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 0.423 s.
    2024-08-18 00:09:28.221 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00006 iterations after 0.446 s.
    2024-08-18 00:09:28.245 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 0.470 s.
    2024-08-18 00:09:28.269 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00008 iterations after 0.494 s.
    2024-08-18 00:09:28.296 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00009 iterations after 0.521 s.
    2024-08-18 00:09:28.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00011 iterations after 0.555 s.
    2024-08-18 00:09:28.389 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00015 iterations after 0.614 s.
    2024-08-18 00:09:28.486 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00022 iterations after 0.710 s.
    2024-08-18 00:09:28.581 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00029 iterations after 0.806 s.
    2024-08-18 00:09:28.680 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00036 iterations after 0.905 s.
    2024-08-18 00:09:28.777 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00043 iterations after 1.001 s.
    2024-08-18 00:09:28.829 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2024-08-18 00:09:28.829 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): 43 iterations, 0.372s init, 0.844s render
    2024-08-18 00:09:29.738 [VERBOSE] :: Requesting current notification data...
    2024-08-18 00:09:29.738 [VERBOSE] :: Requesting default notification data...
    2024-08-18 00:09:30.462 [INFO] :: Clearing the scene...
    2024-08-18 00:09:30.512 [INFO] :: *** Scene Cleared ***
    I think I found the trigger.
    After I rebooted the software, the tests worked fine.
    But I only have to load my project once, and the above problem occurs. Even if you shut down the project and re-import a simple item, there will be problems.
    But once you reboot the software, it's back to normal.
  • crosswindcrosswind Posts: 9,686
    RGB parameters out of range doesn't matter and most of people have this message.
    Your DS version ? and are you using Nvidia Studio driver ? and Version ?
    4.22.0.16
    4060 TI 16G
    Hi, I tried it again this morning, checking the models in the scene one by one.
    Finally, the problem is a model of hair.
    Rose Hair for Genesis 3 and 8 Female(s)
    delete the hair, save it, and open the whole scene without a problem.
    But this hair model, I have used it before, and there is no problem. It's officially sold by DAZ.
    When I tried to import this hair model separately for IRAY preview, the above mentioned problem occurred and I stayed in this shader mode all the time.
    At this point, I'm sure the source of the problem is it, but I don't know what the cause of the problem is.
    2660 x 1531 - 550K
    Ah ~~ this is a hair product from OOT, which used to have a hair blending shader issue when using DS 4.21+.  http://docs.daz3d.com/doku.php/public/read_me/index/56463/start
    Have you updated this hair product via DIM ?
