• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Trying to figure out what DAZ material file names stand for PBR redshift nodes
chad.demosschad.demoss Posts: 23
August 2024 in Cinema 4D Discussion
Ill assume
"D" is diffuse
NM is normal
"R" is roughness? not sure
"SO" I have no idea, maybe specular? where do I plug this in?
"SSS" sub surface scatter - where does this connect to? subsurface "color"?
  • GordigGordig Posts: 10,624
    August 2024
    The first three are correct. SO, if I'm remembering correctly, is a weight map for the detail normal map. In Redshift, you'd want to do something like add the detail normal map tiled correctly for the legs (to use your example), feed that plus the regular legs normal map into a mix node with the SO map as the mix strength. I'm using generic terms because I use Arnold, and don't have that much experience with Redshift.
    As for SSS, personally I never bother with the SSS or translucency maps that Daz products frequently include, and just feed the diffuse map into subsurface color.
    August 2024
    My mistake, W is the detail weight map. From looking through the few G9 skins I have, it looks like SO is AO weight.
  • Willy2Willy2 Posts: 178
    August 2024
    By looking at the image, you can guess the corresponding channel for the material.
    But each 3D software package, in addition to the basic channels for materials, has its own channels because they are closely linked to the native light conception defined by the developers.
    So, rather than looking for (often non-existent) correspondences between this channels, it is preferable to acquire personal skills.
    Easy to match:
    • diffusion channel
    • colour channel
    • bump channel
    • alpha channel
    • transparency channel
    • luminance channel
    • glow channel
    Tricky matching:
    • specularity channel
    • displacement channel
    August 2024
    Willy2 said:
    Easy to match:
    • diffusion channel
    • colour channel
    • bump channel
    • alpha channel
    • luminance channel
    • glow channel
    Tricky matching:
    Those are channels in C4D's standard material system, and the OP is using Redshift. I would also disagree with your assessment of which channels are and are not easy to match, but that's beside the point.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
