(Released) - Penny Hair for Genesis 9 [Commercial]
ToyenToyen Posts: 2,031
edited August 2024 in Daz PA Commercial Products
  • franky85franky85 Posts: 145
    edited August 2024
    Beautiful hair! I have been struggling a bit with the scalp though - I needed to use mesh grabber to fix it. I tried using the scale but it didn't behave as expected. Maybe in the future consider adding adjusment morphs to the scalp part? Unless I'm missing something blatantly obvious :)
    The results however are very nice. Super elegant, and responds well to the old trick of -100% X Scale to flip it around.
    786 x 889 - 338K
    2880 x 3840 - 5M
    Post edited by franky85 on
  • ToyenToyen Posts: 2,031
    This figure/scalp thing a know issue since forever. One solution to this is to set the resolution of your figure to the same number for BOTH viewport as well as render. Let's say you want to render the figure at resolution 3 and your viewport is set to res 1. You also need to set the viewport resolution to 3.
