Problem with a light I can't select.
Hi! I've started a new scene with this asset, and there's a light coming from a fan that I want to edit, both in color and intensity. Normally, I would select it and go to surfaces and emissions, as I've always done, but the problem is that I can't select it; it's as if it doesn't exist. I'm attaching screenshots to show that there's light in the render, but nothing to select. Any ideas?
  • crosswindcrosswind Posts: 10,312
    edited August 2024
    Under the root node of the crime scene, go to "RCS Scene light group" in which there's a point light "PointLight (4)". That's it ~
    Because its property "Visible in Viewport" is turned off, so you could not see it with texture shaded drawstyle. Just turn on Visible in Viewport.
    2022 x 1303 - 3M
    Post edited by crosswind on
    As always, many, many thanks blush
    No problem ~ yes
