MD List of Products Used
Is anyone else having problems with this item.
I load a scene with figure, hair, clothing, run the script.
Results are always the same......the base model
Thanlk you
Thanlk you
Would suggest to ask here https://www.daz3d.com/forums/discussion/689571/list-of-products-used-script-commercial#latest
1st, do not select any node in Scene pane before running the script... then it'll Scan All ~~
2nd, in Settings tab, tick "Always scan all children..."
Be noted, at least for the time being, this script is not able to list any third-party products even if you've installed them to Smart Content (cms database...) with metadata..
According to the readme this uses some or all of http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start and that is certainly, as it stands, stoe agnostic (I think an earlier version did take the daz store as a starting parameter, but even if it did that was editable)
