Questions about Converting Genesis People and Compatibility with Props
n.aspros123n.aspros123 Posts: 333
edited December 2024 in New Users
I'm working on Jill Valentine and Leon S. Kennedy from Resident Evil. I would like to use a pose pack for Genesis 9 people. Pack is made 3D Sugar. Is there an issue from using it?
I'm wondering... Can this pose pack be used just on individuals, E.g: Male or Female G9?
Jill is a Genesis 8/8.1 and Leon S. Kennedy is Genesis 9.
Can Jill along with her Outfit and Props be converted to Genesis 9?
Are there converters that simplify the process?
Post edited by n.aspros123 on
  • GordigGordig Posts: 10,625
    There are pose converters, which you'll need because G9 and G8 have pretty different skeletons.
  • ZiconZicon Posts: 388
    As you can see in your own screen shot, each pose comes in two parts. So yes, you can use these parts individually.
    You can convert a G8 character and wearables to G9, and there are several converters available for this purpose. However, even with converters this is not a trivial process, and the conversion is not perfect. I would not recommend going this route unless your character is unique and irreplacable, you intend to use it frequently and in the long term, and you are willing to invest significant time, effort and skill to get a good conversion.
    It is much easier to grab a pose converter and use the G8 character as is.
  • Can Genesis 8 Weapons (Pistols, Shotguns, etc.) work with Genesis 9 characters?
  • felisfelis Posts: 5,952
     Yes, but it will not autoattach, as the rigging in G9 is different from G8.
    But this product https://www.daz3d.com/prop-minion
    Should in combination with Bone mineons make it possible.
  • crosswindcrosswind Posts: 9,640
    edited August 2024
    Yep ~ and you don't have to buy any products... The steps are shown as the screenshots down below.
    Then, here's a pretty good freebie of Pose Converters from n_alexandru - https://www.renderosity.com/freestuff/items/93511/genesis-1238-pose-converter-for-genesis-9
    Apply G8's Pose Presets with the script. It supports full body poses as well as partial body poses (hands, fingers, etc.)
    The above method will enable using Smart Props from G8 to G9 once and for all. Next time, with other Smart Props, you just need to: dial Clone, load the prop, convert or dial hand poses, parent the prop and Zero Clone ~
    2560 x 1392 - 508K
    2560 x 1392 - 663K
    2560 x 1392 - 669K
    2560 x 1392 - 548K
    2560 x 1392 - 648K
    2560 x 1392 - 704K
    2560 x 1392 - 639K
    Post edited by crosswind on
  • Thank You to everyone for all the answers and replies. Very much appreciated.
    @crosswind Good to hear from you. Hope we can T.V. again soon?
     Can Jill which is 8/8.1F (the one used for the Battle Suit) be converted to Genesis 9? Or, Leon which is Genesis 9 (dodgy jacket) be converted to Genesis 8/8.1?
    Can Genesis 9, in this case the whole Leon character, be converted to Genesis 8/8.1?
  • HighElfHighElf Posts: 373
    No matter in which direction you convert. You can kiss pretty much all shoes and some hairstyles goodbye. Even with converter tools, I have issues with some hairstyles I purchased for G8 and G3 over the years.
  • scorpioscorpio Posts: 8,533
    Just parent the hair and scale move to fit.
