help locking body part in animation
hi i need help from the pros
i tried limb stick its useful altho usually adds a jitter to limb in animation but
i am trying to make an animation in which lower abdomen and lower chest is moving and i want to lock or keep in place uper chest
i am ready to do it manually but even after placing each keyframe it still feels like uper chest is moving slightly because other body parts are moving
is there any method that anybody can suggest ? or a youtube video :)
  • wolf359wolf359 Posts: 3,942
    edited August 2024
    Manually create the animation as best you can and then go into the Dope sheet and delete any keys that are causing unwanted movement in the upper chest area.
    Post edited by wolf359 on
  • what is dope sheet ? and where can i find it ?
  • The dope sheet is the portion of the Timeline pane which lists properties and their keys. The section below that is the graph sheet.
  • currently i am using graphmate to edit animation
    is there anything similar to graphmate ? or better that shows flow of keyframes so i can edit them
    edited August 2024
    The Dopesheet in Daz studio is the area above the Graph editor in this picture.
    GraphMate and it’s companion dope sheet “keyMate” are no longer for sale in the Daz store  but frankly the Daz studio Graph editor and Dope sheet is just as good at this point.
    1893 x 993 - 430K
    1883 x 929 - 365K
    From my expeience, if you want to do animations you need to learn scripting. For your problem I would start with mcjAutoLimb2015 and mcjKeepOrient
    https://www.daz3d.com/forums/discussion/66717/mcjautolimb2015-a-kind-of-ik-system-g3-and-g8-workability-confirmed
    https://www.daz3d.com/forums/discussion/540121/mcjkeeporient
    It is made for hands and legs. I suggest you to modify it for chest.
  • thank you for the help
    i am trying to find a product that was showing a body part movement in view area .... so i can make that line straight by adjusting bend each frame
    dopesheet is useful to look at but not very helpful to make one body part (chest) stick to same place
