Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Well most of that has confused me even more.
I thought a shader was
Shader: A computer program used to determine the final surface properties of an object or image. This often includes arbitrarily complex descriptions of light absorption, diffusion, texture mapping, reflection, refraction, shadowing, surface displacement and post-processing effects. In real-time shading languages there are two different applications of shaders: vertex shaders and pixel shaders.
from the glossary of terms
https://www.daz3d.com/forums/discussion/46/?
I guess I'm wrong, I thought a preset was settings and sometimes textures using a particular Shader, an example - I think would be Iray uber.
But from what you are saying Lady Goo uses a material preset, which as you say cannot be used on anything but the figure/item that it is made for.
Daz products/assets repeatedly use several of these terms in a way that is not industry standard, and not even consistently.
Most "shader" products actually do not include any shaders, and are instead a mix of texture maps and material parameters to be plugged into the existing Iray Uber shader. But then, sometimes shader products *do* include a new underlying shader algorithm.
Within the program itself, a material preset is usually an entire set of parameters/textures to be applied to some/all of the surface zones of a specific asset simultaneously (and therefore relies on finding the correct surface names), and a shader preset is *either* a set of parameters/textures that is not specific to any given asset/surface (and will apply to all currently selected surfaces) or may sometimes be an entirely new shader algorithm (often with a set of preset parameters).
But unfortunately, you can't rely on the terminology used around here. Texture, Material and Shader are often almost interchangeable in how they're used, despite technically having specific meanings.
Still experimenting with her files.
That's why I specified "In Daz Studio, we call..." :)
Whatever the case, you can always copy the surface properties from any item and paste them on your model/prop.
Iray is a game of light, you just need to find the right blend. Also light colors like azure, turquoise, can match better with the light spot of the character. Last but not least, I think using the post denoiser during rendering provide better results (switch on the "Post Denoiser Available" and "Post Denoiser Enable" in the Rendering pane).
The glossary of terms i linked to are for Daz Studio.
I know, but to better explain the concept, think of it as taking part of a math class. Mathematicians love to explain things using methodical and intricate definitions, even when you'll realize that, in the end, the whole thing is just a trivial operation ;D
Little postprocessing never hurts...
..yeah, I know. I used to work in theatrical lighting which was what 3DL lights mimicked. All we had to deal with was colour and intensity. 100% was the highest setting. no 100,000 lumens, light temperature, or whatever (for colours we used gel filters). .
Sadly, just about everything today does come with Iray materials which are more difficult to retro convert than converting 3DL to Iray.
Good for you, @kyoto kid.
After iray had come to Daz Studio, I have never used 3DLight again and I do not miss it at all.
This is such an adorable figure. was quasi an instant purchase. It's too bad that Mechasar doesn't sell the Slime Attack add-on separately. In the bundle is too much stuff I don't have and Slime Attack would go perfectly with Lady Goo.
In the pool
So Mechasar is like a goo whisperer?
Probably while singing "Let it goo!"
What do I say re: Lady Goo? "You goo girl!" (my apologies, couldn't stop myself)
Love the human render! / peace
Something like a Goo Guru?
