XX and XY Bodymorphs
I've been trying to ask around about how to get these body plugins to work within Daz Studio wanted to also ask here, When I load in the body morphs manually I'm met with this list of texture error's then it preloads some grey block that either is on the pelvis or whole body, now i've never had an issue manually loading like this before and i have touch the files or moved them from the downloads folder so I'm kinda stumped on what i need to do here.
Moved to Technical Help as it seems to be an issue with a parrticular set of content, not a Daz Studio issue per se.
I assume this is an anatomical element set. How did you install it?
You don't have XX base product installed... Search 70188 on renderotica site...
