I have a question about add smoothing modifier.
스무딩 반복(Smoothing Iterations)을 켜면 살이 많은 표면이 변형됩니다.
  • n.aspros123n.aspros123 Posts: 336
    Translated to English:  Turning on Smoothing Iterations deforms fleshy surfaces.
  • GordigGordig Posts: 10,668
    That's how smoothing works. If you set clothing to collide with the skin, it doesn't know which bits of skin you want it to collide with, so when you've got skin-on-skin contact, or near to that, it will collide with BOTH bits of skin.
  • Richard HaseltineRichard Haseltine Posts: 109,358
    Using a dForm or Push Modifier to separate the touching parts may help.
