Help with smoothing in Reality for Daz Studio
Widdershins Studio
in The Commons
So I bought Reality to play with and early in I am liking the renders.
I just had a quick question, take a look at this render. To the right of her top you can see polys like it hasn't been smoothed.
In the Iray renderer this is smooth, but not in Reality. Is there something I can adjust to get that smooth like it should be please ?
Many thanks :)
It's the shadow that's not smooth, not the mesh...
Ok, can you suggest anything to remedy it please ?
What light is causing that shadow? If it's a mesh light, try increasing its physical size to make the shadow softer.
I usually fix it with PS postwork
It's a mesh light yes. Scaling it up helped a lot thanks.
You're welcome.
More often than not, that's the simplest fix...if it were a 3Delight render, shadow bias would probably be where to start.
