M3D Horns for Genesis 9 issue
Hi. I recently purchased the M3D Horns, but when I load them on even a base Genesis 9, the fingers around the fingernails becomes distorted. The Horns are the only thing added to the figure, and when I turn them on the fingernails distort and when they are disabled everything is fine.
Anyone else having the same issue?
  • FenixPhoenixFenixPhoenix Posts: 3,187
    I've seen this happen before, and it's usually a faulty morph. The socket morph most probably modified the nails without the PA noticing. Please submit a ticket with the issue for the PA to fix.
  • Thanks!
