Question about VDB Laser Blades and Poses
I seem to be having a number of problems with Daz lately I can't figure out, and here is the latest one.
As said in the title, my question is about this product: https://www.daz3d.com/vdb-laser-blades-and-poses
When I load one of the 'Laser Swords' (there HAS to be another name for them...^_^), and apply the given shaders to both the blade and the volume, the blade always shows as white, no matter what color I use.
In the attached example I used a Red blade, and a Green volume, against a black wall I had for a background.
You can see the green volume nicely, and you can even see a bit of red color on the wall in the back from the blade, but the blade itself comes out white.
I'm not sure why this is, but its the same with a couple of other 'laser sword' props I have, so I suspect its something with Daz overall and not the specific  products.
Anybody else out there run into such a problem (and a possible fix, if it exists)?
