DAZ 4.8 Suddenly Running Slow - SOLVED
mwokeemwokee Posts: 1,275
If I bring up a default figure (any figure) it will appear pixelated and slowly fill in. If I do ANY kind of a change, the figure turns white and eventually pixelates and fills in again.
The turning white is a problem, if I want to adjust eyes, move fingers, adjust props, etc., I can't see the change because it's just a default block of an object and I don't see the changes until after it slowly fills in the pixels again.
DAZ is also running at like 97% of the CPU even when it's in an idle state, no rendering/editing.
I am hoping I got into some kind of viewing mode that can be changed back to a more suitable working environment.
Thanks for any help.
Post edited by fixmypcmike on
  • srieschsriesch Posts: 4,243
    Did you perhaps change the viewport from something like "texture shaded" to "Nvidia Iray"?  If so, just change it back.  Click the icon circled in the screenshot, then from the context menu select whatever your original viewport mode was.
    350 x 342 - 48K
  • mwokeemwokee Posts: 1,275
    Thanks, that was it, case closed...
    Can you edit your thread title please, to remove the last word and add solved to it.
