Loading an older G3 character in DAZ causes a crash, but only if I attempt to view in iray
jdavison67jdavison67 Posts: 689
edited July 2024 in Daz Studio Discussion
I've never had this happen before, and this seems to be specific to this one character... not sure if it's a textue or what but ...
If I view it in any mode (Texture based,filament, wireframe...etc. all is well) if I click to view in iray... Daz crashes. with an exception:
Exception Reason
DAZStudio.exe caused ACCESS_VIOLATION in module "E:\Program Files\DAZ 3D\DAZStudio4\libs\iray\libiray.dll" at 0033:00000000F6CFBBDB, mi_plugin_factory()+2658315 byte(s)
Registers
RAX=000000000014E834  RBX=000000003115B370
RCX=00000000000C4030  RDX=00000000000001A8
RSI=000000003115B370  RDI=000000003115DBD0
FLG=00010212          RBP=000000003115A470
Post edited by jdavison67 on
  • felisfelis Posts: 5,903
    Check if the character have one or more tiff images.
    And If, try to remove then, and if you then can render, save them as jpg or png.
  • LeanaLeana Posts: 12,817
    edited July 2024
    Another thing to check: does the character maybe use an OOT hair with their custom hair shader? This shader can cause problems with recent versions of Iray if you don't use the latest version.
    Post edited by Leana on
  • same here
  • Richard HaseltineRichard Haseltine Posts: 108,500
    leonardo_3285321d said:
    same here
    Same what? Are you echoing the list of things to check? If you are having what you think is the same issue have you checked the things suggested?
  • jdavison67jdavison67 Posts: 689
    Okay....I was able to find another version of the character I saved...that worked ...
    So I brought up them both in my scene...and did a compare...
    I think it had to do with a texture on the skin... which is crazy... but... when I copied the skin from the one that didn't crash to the other...
    I could get them both to work in Iray....
    I'm thinking the first character was created with an early set of iray skin.. or something before the full implementation of the product.....
    Wow!
    Glad I was able to save the character though...
    Thanks for the support though!
    JD
    You know...that may have been related... I did have an OTT hair product on it originally... and I removed it at the same time I did the Skin swap...
    JD
    edited July 2024
    Thanks All!
    Well if you still have the scene with that hair, you can try checking in the surfaces tab if it uses OOT custom shader. In that case, try removing any map applied to Transmitted Colour (click the button to the left of the colour picker and select None).
