Dforce not following adjusted clothes dimensions?
So I tried dforcing a skirt that I modified in length using Fit Control morphs. I noticed that no matter how short or how wide I made the skirt, the end simulated result always goes back to its original length. What's going on here?
  • LeanaLeana Posts: 12,991
    Are you using an animation maybe? In that case the morphs might have been set for frame 1 but not for the last one?
  • RobertDyRobertDy Posts: 274
    edited July 2024
    EDIT: I thought I was doing a still frame but it turned out that it was an animation. Thanks for the tip, it's solved!
    Post edited by RobertDy on
