Less options in filtering compared to tutorial
Hi. My DAZ studio does not have some of the options that the user in tutorial that i'm learning from has. As you can see I lack the option to toggle the "noise Filter Enable" and only have "Noise Degraine Filtering" and lack "Noise Degrain Radius" and "Noise Degrain Blur Difference". Is it beacuse i lack nVidia GPU and use laptop with Intel GPU? (as i understood in such case DAZ ignores the GPU and uses CPU for render?)
  • crosswindcrosswind Posts: 9,712
    IIRC, from a certain version of 4.21+, "Noise Filter Enable" property had been discontinued. Now if you add a non-zero value to "Noise Degrain Filtering", you'll get more Noise degrain properties.
