Duplicate Formulas Found in Files
2»
  • The Skyrim method is hardly infallible, and you can already unisntall and reisntall content (if you load a scene or preset that calls on soemthing you own, and DS knows it, it will offer to isntall it for you).
  • omen.krisomen.kris Posts: 13
    Richard Haseltine said:
    nabob21 said:
    Bejaymac, thanks for the explanation. I do have some questions for you though if you don't mind.
    1. What files are these IDs found in? Are they identified in the error log?
    Yes, the log will give the file name and path
    I can not find the name and path in my log files! The log files are just a mess! Where do I see that any conflict is? How can I find what is causing the problem????  I made the morph myself. What should be unique to not get this freaking error??? Please help!
  • frank0314frank0314 Posts: 15,103
    The errors will have a WARNING in front of the line
  • Richard HaseltineRichard Haseltine Posts: 111,459
    If you made the morph yourself is it controlling other properties, such as joint centres? If so, did you do ERC Freeze once, then tweak or add links and do it a second time? That would certainly create duplicate formulas (you need to use REC Bake, from the right-click menu on the link in the Property Hierarchy - with the morph turned on - to separate the linked properties, then make your changes, then redo the ERC Freeze).
  • EZ3DTVEZ3DTV Posts: 1,637
    edited July 2024
    I have 11,600 Daz items installed and I do not get that issue of duplicate items unless I do something to cause it.
    One of the big causes is having multiple install locations.
    When Daz Download Manager first installs, it tries to install a few things on the C Drive before you get a chance to tell it to install on a secondary drive.
    You must interrupt this process and make sure the DM installs ALL content (other than the Daz program) on the secondary drive. Before it installs any content, make sure you set up your folder locations first or it will fracture your library.
    My advice is uninstall all your content, delete your my Daz3D Library content folder and reinstall it all again. You may even have to look on your C Drive and remove folders there too. I know it takes a while but if you do it right you will no longer have this problem,
    unless you do something to cause it.
    Always keep your downloaded install files for such an occasion.
    One culprit is Turbo Loader. Turbo Loader works great! But if you do not sync Turbo Loader properly it can create duplicate files (morphs) and corrupt your library with duplicates.
    The only solution I have found for this is to do a clean reinstall of everything.
    It always fixes the problem if you make sure ALL your content (starter and bought) is installed in one place only.
    Post edited by EZ3DTV on
    Duplicate Formulas is not duplicate items - it is either two products using the same property name and linking to one or more other properties which also have the same name in each (e.g. SarahFBM driving SarahHead and SarahBody in a two different characters named Sarah, or JaneBody linking to Spine1 X Centre - and no doubt others - in two characters named Jane) or, as I suspect is the case here, a single character having two sets of links between the same properties (again, JaneBody to Spine1 X Centre if the maker decided that the initial adjustment wasn't quite right and tried refining it without first baking out the original formula).
  • crosswindcrosswind Posts: 10,281
    Yes, as Richard mentioned, it doesn't matter with duplicate files other than duplicate URIs / formulas.
    As for Turbo Loaders, they don't create either duplicate files or duplicate formulas even if one does something wrong with it. But they may bring wrong results of morph... if one partially deactivates dsf files under a single product 'cause ERC kinks may break.
    edited July 2024
    As I said I have 11,000+ assets and I never get duplicate file/formula errors.
    I laid out how the Download Manger installs a glut of files and then offers you the ability to change content locations.
    This initial install must be prevented and default locations set before any files get installed or your library will be fractured.
    In this case updates may be installed in an incorrect place resulting in duplicate files.
    As for Turbo Loader yes it deals with morphs but the error message you get when you create duplicate morphs (which is very easy to do with turbo loader) is the standard duplicate "file" error.
    It does not say duplicate morphs is says duplicate files/formulas.
    I have had to reinstall 11,000 assets twice due to Turbo Loader creating "duplicate files/formulas".
    Crosswind, do you own all of the Turbo Loader scrtipts for all of the Genesis figures?
    Have you used it on a regular basis? I have...
    When you have 11,000 assets it can become quite necessary.
    It is very easy to click the wrong thing and end up wiith the duplicate "file" error when using Turbo Loader.
    Once this error surfaces the only sure way to fix it is to reinstall your content.
    One wrong click with Turbo Loader can duplicate "thousands" of files. Yes, thousands.
    Files, morphs, formulas whatever, you get the same duplicate file error message.
    I believe most duplicate files/formulas get discovered by Daz rather quickly and patched.
    But duplicate files/formulas created by a fractured library is much more subtle and harder to troubleshoot.
    A fractured library is a less reported culpret.
    edited July 2024
    I've not seen that "duplicate files/formulas" error so far... maybe you can show me how to reproduce it. I just own Turbo Loader for G3, G8 as well as Booster Utilities, and yea, I used to use them pretty frequently, I have nearly 30+ morph assets.
    But since DS 4.21+ when the asset loading speed had been siginificantly improved, now I rarely use them, probably on quarterly or semiyearly basis lah ~~ but I still keep quite a lot of morphs disabled.
    Post edited by crosswind on
    Duplicate files and duplicate forumlas are not the same thing, and this thread is about the latter so advice relating to the former is not helpful.
    Duplicate files and formulas can be casued by the same root problem, a fractured library. So advice relating to the former can be helpful in such a case as a fractured library.
    I will reiterate, I have 110,00+ Daz assets and I never get issues with duplicate formulas or files... Oh, but I took care not to let the Install Manager fracture my library.
    It seem Richard that you have made an assumption that it must be duplicarte formulas rather than duplicate assets in different places which can prompt the same error message.
    When a reinstall of content eliminates the error message, I guess there was not really a duplicate formula, right?
    edited July 2024
    I would respond to your question but I don't want to deal with Richard complaining about me diverting the tread topic.
    Even though the original poster did not rule out the possible use of Turbo Loader.
    I would start a topic on the subject but it has to be phrased as a question and not a "discussion" like it says in the forum. These are supposed to be "discussions". Richard would complain about that as well.
    This is a discussion on duplicate formulas which one would think also encompases duplicate files which can create the same exact error message.
    A duplicate file that contains a duplicate formula. Yes, there is such a thing...
    Duplicate Formulas Found in "FILES"...
    The problem is not alwsy the duplicate formula... but it is the duplicate file containing the formula.
    Duplicate files do not cause duplicate formulas, as DS only loads the first file it finds, like in a case where products have been installed with both, DIM and Daz Connect (inside DS).
    edited July 2024
    Your response makes sense PerttiA, thanks for clarifying that.
    The error massage then goes on and says, "make sure your content is properly installed".
    How would reinstalling change a duplicate line of code in a file?
     Why bother to even mention reinstalling if duplicate files are not in play?
    Duplicate file formulas that are not updated due to them being in the wrong location.  i.e. a fractured library.
    In such a case, a duplicate file can prevent an updated file from being used.
    Becasue Daz is seeing the unupdated file first.
    I do use primarily Genesis 8 and 9 figures so this is probably why I do not encounter this problem, and my library is installed properly as well.
    Because the message assumes the the products that were installed, were not badly made.
    Reinstalling helps if the file was fixed, ie. the formula changed so that it doesn't clash with another formula inside another file that belongs to a completely different product, which may for example happen if the products are from the same creator and the creator has cut corners, reusing some of the files (the contents of the files) and forgetting to change all the formulas that need changing.
    edited July 2024
    If a product has an update, one would think it would get installed routinely as it comes out.
    And an update will not fix a fractured library because Daz may continue to see the unupdated "duplicate" file over the updated one.
    It all depends on which version of the file Daz favors.
    Does Daz pick the first file it encounters or the file with the latest install date?
    Regardless, a duplicate file could be in play.
    In such a case, a proper and clean install of content is the best fix.
    DS goes through the content libraries in the order that is specified in "Content Directory Manager" and loads the first file it finds.
    The error message specifies duplicate formulas, so I don't think it is much of an assumption. It is also rather diverting this thread from its proper purpose, trying to help the user solve their problem (or get it solved if it is down to add-ons from a store or freebie maker).
    edited July 2024
    It depends, if the duplicate formula is left from a fractured install of an old unupdated file, it was a duplicate file containing a formula that did not get updated.
    Daz chose to load the unupdated formula instead of the duplicate updated formula.
    So yes, it indeed was a duplicate formula on a fractured install that was deleted and replaced by a clean install that contained only the updated formula.
    Updates only update one instance of an asset. Depending on the DM settings, updates may even create a new instance of the asset.
    Perhaps Daz may prefer the duplicate file with the latest install date but of that I am not certain.
    A proper clean install rectifies the duplication with possibly newer files.
    I just wanted to point out that it can be a library conflict.
    The Daz library has many opportunities to fracture itself.
  • vectorinusvectorinus Posts: 149
    crosswind said:
    I've not seen that "duplicate files/formulas" error so far... maybe you can show me how to reproduce it...
     You can reproduce this error by downloading the old Genesis 1 base figure in scene. Daz Studio will notify you of duplicate formulas found and direct you to the log file. In the log.txt you need to find the line Duplicate formula found. After this line comes the name of the first of the conflicting files (tag Previous:). And after the Duplicate: tag there is the path to the second file. After the input: and output: tags, you will see identifiers that have the same names in both files. This is the problem. Because, as noted earlier in this thread, identifiers must have unique names. You can change the identifier in one of the files and the message about duplicate formulas will disappear. Will the morph work? Of course, it would be better if the author corrected the file. However, he could be helped if you provide him with the information obtained from the log file.
    edited July 2024
    Thanks ! I know well about duplicate formulas... I just asked that question out of curiosity as RexRed mentioned he had experienced that issue with Turbo Loader.
    As for G1, I never use it ... so I only have its Starter Essentials. After I loaded it for checking, I found no duplicate formulas issue. I'm not sure if you meant an issue came from the essential product or any other G1 chars...
    Glad to be of some help to you! I hope we will also be useful for everyone interested in this problem, including myself.
    Yes, Daz fixed a bug in the Genesis morph base files a long time ago. And it is no longer possible to reproduce this problem on new Genesis 1 samples. Since omen.kris created his own morph with a duplicate formula, he could share with us a fragment of his log file starting with the line Duplicate formulas found. And here is a sample of my log related to the old Genesis model.
    2024-07-03 00:54:35.784 [INFO] :: Prepare asset load (open): /People/Genesis/Genesis.duf
    2024-07-03 00:54:35.839 [INFO] :: Begin asset load (open): /People/Genesis/Genesis.duf
    2024-07-03 00:54:35.849 [INFO] :: Clearing the scene...
    2024-07-03 00:54:36.167 [INFO] :: *** Scene Cleared ***
    2024-07-03 00:54:36.167 [INFO] :: Determining missing assets...
    2024-07-03 00:54:36.294 [INFO] :: Setting textures...
    2024-07-03 00:54:36.321 [INFO] :: Scanning for addons...
    2024-07-03 00:54:37.156 [INFO] :: Creating node geometry...
    2024-07-03 00:54:37.163 [INFO] :: Creating UV sets...
    2024-07-03 00:54:37.164 [INFO] :: Creating materials...
    2024-07-03 00:54:37.168 [INFO] :: Resolving legacy figures...
    2024-07-03 00:54:37.168 [INFO] :: Preparing modifiers...
    2024-07-03 00:54:37.181 [INFO] :: Creating modifiers...
    2024-07-03 00:54:37.341 [INFO] :: Resolving 31142 formulas...
    2024-07-03 00:54:37.341 [INFO] :: Finding formula properties...
    2024-07-03 00:54:37.356 [INFO] :: Sorting formula properties...
    2024-07-03 00:54:37.356 [INFO] :: Creating ERC Links...
    2024-07-03 00:54:37.535 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(989): Duplicate formula found:
    Previous:
    File: /data/DAZ 3D/Genesis/Base/Morphs/DAZ3D/Expressions/PHMFlirtingMasculineR.dsf              // First conflicting file
    Owner: Genesis
    Input URI: head:/data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Expressions/CTRLFlirtingMasculineR.dsf#CTRLFlirtingMasculineR?value
    Input: CTRLFlirtingMasculineR
    Output URI: Genesis:/data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Expressions/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value
    Output: PHMFlirtingMasculineR
    Duplicate:
    File: /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expressions/CTRLFlirtingMasculineR.dsf                   // Second conflicting file
    Owner: head
    2024-07-03 00:54:37.537 [INFO] :: Finished resolving formulas.
    2024-07-03 00:54:37.541 [INFO] :: Applying animations...
    2024-07-03 00:54:37.542 [INFO] :: Finalizing modifiers...
    2024-07-03 00:54:37.542 [INFO] :: Finalizing channels...
    2024-07-03 00:54:37.542 [INFO] :: Finalizing materials...
    2024-07-03 00:54:37.542 [INFO] :: Sorting property groups...
    2024-07-03 00:54:37.544 [INFO] :: Marking duplicate formulas...
    2024-07-03 00:54:41.034 [INFO] :: Finished asset load (open): 0m 5.195s - /People/Genesis/Genesis.duf
    I edited the log a little. I placed the part we needed between the rows of exclamation marks. The same formulas are highlighted in red, and the names of the files containing these formulas are in blue. Comments in black bold font were also added by me, do not expect them in the real log.
  • awdzawdz Posts: 19
    edited September 2024
    Hey folks, I'm hoping maybe someone can help me troubleshoot this same issue...maybe same issue?  See below for the log entries, but the weird, frustrating thing is that they all seem to be the same file, and when I go to the file locations, I can indeed see that they are the same file....?  How can it be a conflict when there appears to be no difference?  Thank you!  I'm a newbie when it comes to trying to troubleshoot Daz3d files.
    2024-09-29 20:14:46.356 [INFO] :: Sorting formula properties...
    2024-09-29 20:14:46.364 [INFO] :: Creating ERC Links...
    2024-09-29 20:14:48.463 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(989): Duplicate formula found:
    Previous:
    File: /data/Daz 3D/Genesis 9/Base/Morphs/Luna3D/-G9-Young-01/-G9-Young-01.dsf
    Owner: Genesis9
    Input URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/Luna3D/-G9-Young-01/-G9-Young-01.dsf#-G9-Young-01?value
    Input: -G9-Young-01
    Output URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/DAZ%203D/FACS/facs_ctrl_MouthStickyPower.dsf#facs_ctrl_MouthStickyPower?value
    Output: facs_ctrl_MouthStickyPower
    Duplicate:
    Owner: Genesis9
    Input: -G9-Young-01
    2024-09-29 20:14:48.488 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(989): Duplicate formula found:
    Previous:
    Owner: Genesis9
    Input: -G9-Young-01
    Output URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/DAZ%203D/FACS/facs_ctrl_EyeLookAuto.dsf#facs_ctrl_EyeLookAuto?value
    Output: facs_ctrl_EyeLookAuto
    Duplicate:
    Owner: Genesis9
    Input: -G9-Young-01
    2024-09-29 20:14:48.643 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(989): Duplicate formula found:
    Previous:
    Owner: Genesis9
    Input: -G9-Young-01
    Output URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/DAZ%203D/Base%20Correctives/body_ctrl_basejointcorrectives.dsf#body_basejointcorrectives?value
    Output: body_ctrl_basejointcorrectives
    Duplicate:
    Owner: Genesis9
    Input: -G9-Young-01
    Post edited by awdz on
    Yea, duplicate formula issue can either come from duplicate morph IDs (aka URLs) in different DSF files or come from very same duplicate or multiple formulas within one single DSF file.
    You can simply open that DSF file with Notepad++ to check if it's the latter case.
    Fabulous.  I uncompressed the file, loaded it in NPP, and spotted the duplicates easily.  Deleted, and I'm good to go.  Thank you!
