CMS Gone
I had a masses computer fail, thanks norton, and after a reinstall of DAZ my CMS is gone. I still have a content library full of stuff but no smart props, is there any way to to bring back my stuff? See attached pix
Try:
Hi Jag11, I tried re-import with no luck, see attached file. Everything looks right doing the reload but after processing no smart content. I did reboot after the re-import as well.
Can't see the attachment.
Also check you have DAZ Studio and PostgreSQL CMS properly installed, if the CMS is not installed that might be the reason you see no content.
Hi Jag11, it was the PostgrSQL CMS, it wasn't installed. Thank you for your help.
