Daz Studio drop down menu "problem"?
Hello there folks,
I've got a curious problem that may or may not be a problem after all to do with the drop down menus
I have Daz Studio (now at 4.15) on two laptops, an older Windows 7 machine and a newer Windows 10 machine.
Each time I update Laptop7 (I'll call it that) the splash screen changes whilst the Laptop10 remains the same.
Now I have this curious problem.
On laptop7 the drop down edit menu offers lots under the "object" category, whilst laptop10 displays "change parent" as the only option - nothing else for the "object" category.
However laptop10 has a lot more in the "Create" drop down menu than laptop7.
Is there an issue here - I can find the missing object functions in the scene menu on a right click.
I have heard that different operating systems may produce altered styles.
Is there is a problem with laptop10 is there an easy way to fix the menus? It was doing this in 4.14 and I thought the update would fix the issue so I don't think an uninstall/reinstall will correct the issue. If one was to delete the appdata folder would it force Daz studio to reset itself to default?
Regards
Steve C
  • Are both running as Pro (with a serial number)? Have you tried reloading the layout, or just using Window>Workspace>Update and Merge Menus? What do you mean by the splash screen changing - it could indicate that the layout is "stale", in which case one of the steps above may also fix it, but the description isn't entirely clear.
  • ScoopeyScoopey Posts: 191
    Not tried reloading layout. Did not want to screw anything up lol!
    By chance I found a forum entry from 2018 where someone had the same problem and the solution suggested was to reload the layout.
    Saving the "faulty" layout and reloading worked!
  • rinyou321rinyou321 Posts: 0
    Yo thank you so much, spent hours trying to figure out why I couldn't select anything and why viewport drop down menus weren't clickable but this solution worked. TYSM!
