Genesis 9 No Breast/Pectoral.. Possible?
Mana LuCune
Hi
From title, I am asking if there's a paramter to remove breasts (Pectoral) from a Genesis 9 female character?
Thanks
not in the base figure, but if you have the Genesis 9 body shapes(https://www.daz3d.com/genesis-9-body-shapes ) there are morphs called breast gone and breast small that might do what you're looking for.
Those morphs especially Breasts Gone can just perfectly work on G9 Base figure. If you want the breasts 100% gone on other G9 characters, it won't give you expected results, just as you mentioned.
You have to further fix it in external sculpting software if you do need to see 100% flat on the character's chest... like Victoria 9 down below.
Actually it's not really a fault... Technically, the vendor could create an MCM (Morph Corrective Morph) for each character, just like what I did, but practically it's not really possible... so that's why we better learn how to fix it.
You did it well!
I've picked up a number of general-purpose morph packs for G9. It sometimes takes quite a bit of trial and error, but I can generally find some combination to flatten out just about anything.
You could just use Blender bridge and fix it there.You can also use any modeler you choose see videos on youtube.
Hi, there's also the left and right chest volume, 2 morphs, for some reason, separated from the rest and found under "tools"(warning, writing this from impaired memory
) And Zev0's GU product has a flatten chest morph - to use it, first just set the main GU body morph to any value slightly over zero. Of course you can just scale the pectorals manually and mess with the scale of spine 3 - disclaimer, all of that probably wouldn't do what you intended cause of the extreme change necessary but that's some extra stuff to use, especially dealing with base G9's giant pecs
/ peace P.S. I've found I can do some radical scaling/ morphing, add lots of generic smoothing, then sucessfully bake the smoothing modifier to create something very useable and different from the original.
Be prepared, that for some reason, I don't quite understand, you will get mesh glitches in the chest area of your clothings.
Mostly it will look like the sternum part of clothing will stick out.
Yeah, you finally fix the chest then hardly anything fits. I was happy to see G9 return to something like G1, but I frequently fit G1 clothes to G9 better than G9 clothes on G9 with a flattened chest. I've been experimenting with smoothing the clothes and baking it or updating geometry, but I guess I need more info to make it work - afaik, it's possible. The search for tuts goes on
/ peace P.S. Thank you Masterstroke for your freebies!
