UltraScenery - new(er) territory [Commercial]
1303133353667
  • memcneil70memcneil70 Posts: 5,515
    Linwelly said:
    I didn't read through all of the messages in this thread, so apologies if this has already been mentioned,
    I'm currently working through the comprehensive guide by Martin and Digital art life and noticed that the affiniti doesnt activate for some biomes, there was one grassland I had selected first that didn't activate the + in the affinity box and now the fallen oak leaves 3 dont do it either.
    I experimented with the viewport eye open for the respective biomes but that didn't change anything (aside from making my computer extremely slow crying)
    So either I'm missing something of this might be a bug?
    @Linwelly, I am also finding this particular process 'atrack/repel' kind of hit or miss. I am not sure why some items don't trigger that + or add button, other than maybe the order in which the biomes are listed? I am also working through the tutorial, but I keep getting interrupted with life issues, so I have to go back to previous videos to remind myself where I was, then continue on. I will keep an eye out hoping a more skilled person than me answers your question.
    Mary
  • AnEye4ArtAnEye4Art Posts: 861
    Excuse my question as I don't spend a lot of time playing with this stuff, but what does afinity do anyway?
    edited June 2024
    This is a test render using gaea for the lava terrain, US2 and embergen for the vdb steam clouds. I call this: where the lava meets the stream.......you get steam. Duh!!
    2688 x 1512 - 1M
    Post edited by AnEye4Art on
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,745
    edited June 2024
    Affinity determines whether things in one layer are attracted to, or repelled by, things in another layer. Here is an example from one of the USC2 Oaks sets. I have selected the Fallen Leaves layer and down below, you can see that it has two Affinity settings - one each for the two types of trees noted. To the right, you can where I've opened the Affinity setting for Fallen Leaves to the Oaks Large layer: they are attracted to the trees. Hence, you see a preponderance of fallen leaves around the trees. Conversely, you would see an Affinity set up to Repel for flowers and trees - flowers generally don't grow in great numbers directly underneath large trees.
    1180 x 848 - 236K
    Post edited by paulawp (marahzen) on
  • SilverGirlSilverGirl Posts: 3,229
    Okay, I read through the posts in this thread and watched the tutorial video... I'm not sure if what I want to do wasn't covered, was covered and I'm just particularly dense, or isn't possible.
    I want to create a terrain with rises and dips (and a lake) in particular locations. I get that the height maps control the highs and lows, but I really doubt I'm going to find one pre-made that works for this, and oh my gosh I am NOT skilled enough to create my own.
    Is there a way to alter terrain height/depth on the fly in the scene itself? I tried Mesh Grabber, and it might be my own lack of skill and finesse, but it didn't work well.
    Suggestions?
    (Wait for Mesh Grabber 2?)
  • TotteTotte Posts: 14,843
    Suggestions?
    For this, and also for easy masking, Mask Builder II will hopefully come to a store near you "daz-soon".
    Maskbuilder in combination with changing  the USC2 terrain parameters works, even though it's not as easy as it was with USC1 due to how USC2 works internally.
    Suggestions?
    Thanks for your response! I'm okay with it being fiddly as long as it works in the end.... I've started to learn that most anything I want in Daz is going to require it. (And hey, I never really got going far on USC1, so no point of comparison here!)
    Looks like I'll wait for Mask Builder 2 to drop and try pounding the nail in with a tool instead of my forehead. cheeky
    Will there be a YouTube video or something of the sort to go with it? I always learn better from those than written documentation.
    Suggestions?
    There might be one by MartinJFrost (the same way he did one for USC2 where he showed a bit of Alieantor Pro II), nothing decided yet.
  • LinwellyLinwelly Posts: 6,067
    comparing your and my screenshot, I have the impression you generally use the same leaves as I tried, but the overall setup is a bit different. And yours seem to work.
    I checked if I missed an update of USC2 in the DIM but none shows, so did I miss something?
  • alexhcowleyalexhcowley Posts: 2,404
    The last update I am aware of was around about the 4th of June. @barbult helpfully posted a note on this subject which is very helpful for those of us who prefer  manual install.
    Cheers,
    Alex.
    Cheers,
    Alex.
    thanks for the pointer, I guess since I installed the whole of it on the 11th of June all updates should be included already
    edited June 2024
    Another angle of the volcano with a different vdb smoke from embergen.
    2688 x 1512 - 927K
  • Steel RatSteel Rat Posts: 417
    HowieFarkes said:
    Steel Rat said:
    Still no word about the "Atmospheres" mentioned in the promo?
    I think they're referring to the Iray Sun/Sky system built into DAZ Studio there.
    Sorry, that's not obvious in any way. They should change that, because I was expecting something new with this product.
    So I have been using USC1 a lot, to render top down encounter maps for Role-Playing games. I usually render the whole scene, then just the ground and underbrush, then just the trees. Doesn't seem possible to render separate objects with USC2, since they can't be selected in the scene.
    edited June 2024
    Instances to Objects might work for you: https://www.daz3d.com/instances-to-objects ;
    Thanks, but that would add another level of complexity, and steps to a relatively simple process  in USC1.
  • johnjohn808johnjohn808 Posts: 179
    edited June 2024
    How do you edit the height map in ultrascenery2 when using classic content?
    Post edited by johnjohn808 on
    Hi,
    are you "that" Steel Rat from the Dundjinni and Greytale era?
  • tubbesingtubbesing Posts: 55
    I assume this question has been answered already, but it has eluded my searches:
    What’s the difference between UltraScenery and UltraScenery 2?
    _________________
    According to the Daz store, UltraScenery 2 does this:
    1. Customization via dials and dropdown settings
    2. Import real landscape height maps
    3. Water presets, customizable settings via dials and dropdowns
    4. Terrains built on mixed Biome layers, customizable via interface
    5. Atmosphere uses Iray settings for faster, more up-to-date renders
    _________________
    Is all that true of UltraScenery as well? Do add-ons for one work with the other?
    Thanks.
    _________________
    _________________
    Thanks.
    Main points from a USC2 user perspective compared to USC1:
    - No more edit your changes and generate, wait wait wait, changes now are live.
    - Larger area.
    - Easy to add Biome layers and mix layers between USC2 Ecologies ( Classic Ecologies works but no mix-in for those, but you can mix on new Biome layers in with Classic ecologies)
    - Everything is in a tab pane and not a script, easier to work with, and faster to work with.
    If you with add-ons mean Ecologies and Features, yes they work, but some might now work as well on larger than 64x64 terrains, depending on what they are.
    If you mean UST-1 and UST-2, the answer is no. Many of the things they added are now already in USC2, and Alienator Pro II and Mask Builder II are coming...
  • MartinjfrostMartinjfrost Posts: 407
    Affinitys only work on itmes below the item you are wanting them to be affected by in the biome list ( you can move them around using the up and down arrows) so if your leaves are at the top of the list they wont be active. Move them to the bottom of the list and then they will be re active with all the layers above them.
    Oh thanks a lot, I'm glad it's a simple solution like that
    edited June 2024
    so once I know how, it's actually working as well, who would have though wink
    800 x 600 - 1M
    Post edited by Linwelly on
    It reminds me of using photoshop layers in a lot of ways.
    Lovely image @Linwelly
    edited June 2024
    Just playing around, and looking forward to all the various add-ons and extensions becoming available, updated for USC2.
    What causes the little blue/green sparkles in water?
    1300 x 1000 - 1M
    thank you!
    I never used Photoshop, always been a GIMP gal but yes keeping that concept in mind might help me for the next steps
  • FishtalesFishtales Posts: 6,219
    edited June 2024
    Duck Bay
    2024-06-22 09:16:10.030 [INFO] :: Total Rendering Time: 31 minutes 10.34 seconds
    Click on image for full size.
    1920 x 1080 - 2M
    Post edited by Fishtales on
  • DoctorJellybeanDoctorJellybean Posts: 9,760
    Fishtales said:
    Duck Bay
    Very nice!
